Too much bumpsteer
Old 05-28-2010 | 03:12 AM
nestle_!9's Avatar
nestle_!9
Too much bumpsteer
Dropped on TANABE's coilovers. And everytime I hit a bump, My steering wheel feels loose and unstable (bump steer). What can I do about it? thanks
Old 05-28-2010 | 03:24 AM
j784wrx's Avatar
j784wrx
you need a company to make a bump steer/roll center kit for the g37
something like this
350zMotorSports.com 480-829-4908 | Moonface Racing Roll Center Adjuster 350Z
Old 05-28-2010 | 03:26 AM
nestle_!9's Avatar
nestle_!9
Well I dont have the power to do that at the moment, but thanks anyway. Anything like to adjust alignment, raise the car a lil bit ? Anything to reduce the bump steer?
Old 05-28-2010 | 05:51 PM
G_rev's Avatar
G_rev
Did you get an alignment after you installed the coilovers? Most likely what causes that bumpsteer is a bad alignment.
Old 05-29-2010 | 04:21 AM
nestle_!9's Avatar
nestle_!9
I did with Firestone. but I don't think they did it right. ill try another shop
Old 05-29-2010 | 07:43 PM
TJHG37S's Avatar
TJHG37S
Take if back to Firestone and have them fix it.
Old 06-01-2010 | 06:15 PM
oreoleo's Avatar
oreoleo
I wonder if the moonfaces are g37 compatible. 500 bux is steep...
Old 06-01-2010 | 09:30 PM
goomba's Avatar
goomba
Car is too low. Need to raise it.
Old 06-03-2010 | 12:47 AM
oreoleo's Avatar
oreoleo
There is no such thing as too low :P
Old 06-21-2010 | 11:24 PM
oreoleo's Avatar
oreoleo
Got this email from a moonface rep about a g37 kit
Dear Mr. Oren,
Thank you for your enquiry.
Nissan 370gt is the same standard as V36 Nissan Skyline sold in Japan.
Here we sell “Role Center Adaptor” and “Low Angle Adaptor” for V36 Nissan Skyline.
They will be fit for your 370gt.
Please check below website.
[RC Adaptor]
£Ò£Ã¥¢¥À¥×¥¿¡¼ SAD13 - SUPERLAP - ¹ñ»º¥¹¥Ý¡¼¥ÄÀìÍѥѡ¼¥Ä¥Ö¥é¥ó¥É
[Low Angle Adaptor]
¥í¡¼¥¢¥ó¥°¥ë¥¢¥À¥×¥¿¡¼ ¡Ê£Ò£ò¡Ë SLD12 - SUPERLAP - ¹ñ»º¥¹¥Ý¡¼¥ÄÀìÍѥѡ¼¥Ä¥Ö¥é¥ó¥É
To gain English version of site, please click “Oversea Customer” left side at the bottom.
Then click and go “Role Center Adaptor” and “Low Angle Adaptor”
Best Regards,
Itsuroh Abe
Moonface Oversea
itsuroh@moonface.co.jp
Old 06-22-2010 | 08:45 PM
goomba's Avatar
goomba
haha for asthetics definitely not.. but whats happening is that car is so low that the suspension geometry is out of whack at the slammed ride height. The steering linkage is moving in a smaller arc than the control arms which causes the bumpsteer. An alignment isn't going to fix that. Either raise the car or make a custom roll center adjustment kit to fix the problem.
Old 07-14-2010 | 12:45 AM
oreoleo's Avatar
oreoleo
I meant to say that there is almost always a solution
Old 07-14-2010 | 03:57 AM
Presto's Avatar
Presto
how low are you dropped? if you drop only 1-1.5inches i dont think you should have the problem. did you sort out your alignment?
Old 07-06-2012 | 04:14 PM
MyocyteX's Avatar
MyocyteX
Wonder if the OP ever got this problem fixed...
sales@czp
Brakes/Suspension
124
12-06-2017 02:26 PM
FBPARTS
Brakes/Suspension
295
12-01-2015 02:30 PM
nestle_!9
11-22-2009 03:43 PM
