Has anyone had problems with their SPC camber kits?
On my last g35 coupe I put both front and rear camber kits on and after a few days of very mild driving, I was taking a VERY slow (thank God it was slow) left turn and the top knuckle bolt ripped right through the top of the a-arm. The wheel was just sitting there crooked. I later took it in and they put some washers in there to prevent the bolt from ripping through the the obviously oversized and weak hole. Is this issue resolved already?
many had problems. i just read through the entire thread
https://www.myg37.com/forums/brakes-...it-rattle.html
seems like no one confirmed if spc finally fixed the problems and redesigned the kit for the g37.
their temporary fix was using g35 front camber arms or add tons of washers or something
did spc redesign the front camber arms after many complained of it hitting the body of the car?
is there a new part # for the revised version? if we order one from a vendor how do we know if we get the old part or the new revised version?
it seems 72130 is the part # for the g35 front camber arms which correct only 1.5 degrees of camber according to Jeff from spc (post #183)
so guess they just switched to using the g35 arms instead of designing a new one for the g37.
I'm eating up front tires until they come out with their front camber solution that's currently in development. From speaking to them directly I couldn't get a firm release date (probably going to be a while), but it will adjust front camber completely differently from anything out currently.
