Eibach installed
Old 03-16-2010, 10:00 PM
JMacsG37
JMacsG37's Avatar
Ya, I've definitely enjoyed my Eibach's. I do wish they were a little lower though.
Old 03-18-2010, 03:24 AM
GraphiteG37S
GraphiteG37S's Avatar
I'm thinking about doing eibach pro kit on my g37s coupe. I've got wider wheels and tires on right now and I'm wondering if it is going to be necessary to add a camber kit to get back to almost oem spec camber. Can anyone answerr this who has used the eibach prokit and has wider wheels and tires? Thanks.
Old 03-18-2010, 03:39 AM
beerme986
beerme986's Avatar
many people have the eibach and are running wide tires. I am dropped on eibach and running 245/35/20 and 275/30/20 with no rub (of course offsets play a role in this as well) as long as you take it to a performance shop that does good alignments, you will not need an camber kit. dont get alignment at pep boys or such
Old 03-18-2010, 11:50 AM
GraphiteG37S
I'm running 255 and 275 on 20" rims. The offset is good that it won't rub. I just was wonder if the alignment would he able to get it close to oem camber specs. Thanks.
You happy with your eibachs?
Old 04-07-2010, 12:10 AM
Juank 6MT
Juank 6MT's Avatar
Hey !
your car looks very nice, i have a 2010 4dr 6mt and i will like to
get the same springs, so can you please let me know where did you
bought them?
Tnx...
Old 04-13-2010, 03:23 PM
MDG37S
MDG37S's Avatar
Kanji,
The drop looks great. I am getting Eibachs, too. In your opinion, what spacers do you think will fit best to get the stock wheels closer to the fender without rubbing?
Thanks.
Old 04-13-2010, 03:24 PM
MDG37S
MDG37S's Avatar
Originally Posted by Juank 6MT
Hey !
bought them?
Tnx...
Check with some of the sponsor vendors. Should be mid-$200's or so.
Old 05-05-2010, 02:14 AM
MFRESH
MFRESH's Avatar
beerme986,
When you installed you eibach pro kit did you do your alignment right after and the rear wheels were sitting flush on the ground? Or did you wait a week like what i've been hearing every1 does and then do the alignment?
I installed the eibach springs and did the alignment there after but the rear wheels are not straight on the ground. The bottom part of the wheel is a little out and top is a little inside the fender. Basically slanted like so "/" not that exaggerated of course but just for illustration purposed. Is the what they call negative camber? Anyone knows a performance shop thats does good alignment in Queens, NY?
Old 05-05-2010, 11:13 AM
Exige
Exige's Avatar
Wow every time I see this done It makes me want it more and more! I need to stop slacking.
Old 05-05-2010, 11:18 AM
hispeed-lowdrag
hispeed-lowdrag's Avatar
Originally Posted by MFRESH
beerme986,
yes, negative camber is when the tires are // inside \\
ideally you should wait a week or two before getting an allignment to allow the springs to settle
Old 05-05-2010, 08:20 PM
MFRESH
MFRESH's Avatar
Yeah you really need to stop slacking and get it. Major difference for a suddle drop.
Old 05-06-2010, 11:32 AM
Exige
Exige's Avatar
I have been considering coils now too but the springs are just so easy and cheap! haha
Old 05-06-2010, 11:45 AM
beerme986
beerme986's Avatar
i got my alignment done right away, the drop is sublte enough where any further settling wouldnt effect the alignment (others will disagree). My tire wear is fine from doing this and yes it has a slight negative camber, which you want anyway.
there are a bunch of places on new york that do this stuff. I'll PM where you can find them.
Old 05-06-2010, 04:57 PM
  #29
lmwebster
lmwebster's Avatar
Re: negative camber. I am thinking of getting the eibach pro kit and a set of vossems, style still being considered, but maybe I am the only one that when I pull up behind another g37s and see the tilted wheels hate the look. I guess the question is will the eibachs cause this or is what I am seeing from more agressive lowering?
Re: Eibachs and 20 vossems. Is it also out of the question to run 255 & 285 20s as opposed to the norm 245 & 275 20s without rubbing.
Thx - Lawrence
superjoey
31
03-22-2023 11:56 PM
Team_STILLEN
Future Models
13
09-05-2016 03:13 PM
Thedbarz
33
02-09-2016 12:05 AM
WillCo1
09-01-2015 11:31 PM
cparise
08-19-2015 01:51 PM
Quick Reply: Eibach installed
