so my brakes wouldnt work? the hell
Old 02-16-2010 | 01:43 PM
chasemyaccord's Avatar
chasemyaccord
I guess I'm kinda slow then. I didn't understand that the parking brake was engaged in the first place. Then I missed the part where he disengaged it on the incline before engaging a gear. I'm out because I'm not smart enough to follow the story.
Best of luck solving the issue.
^ Killed too many brain cells celebrating after the Saints won.
Did you have the engine on or off while doing all this?
Old 02-16-2010 | 03:21 PM
terrycs's Avatar
terrycs
Assuming there wasn't a pool of brake fluid under your car, it sounds like a air stuck in the system somewhere. Dealer fix.
Old 02-16-2010 | 03:42 PM
Blackjack's Avatar
Blackjack
^ That's what first came to my mind as well, Terry.
Old 02-16-2010 | 03:57 PM
Dvit's Avatar
Dvit
So you parked on an uphill incline and left the car in 1st WITHOUT engaging the parking brake? Then returned to the car and pressed the brake and clutch and it rolled backward? The problem is in the driver seat, not the brake system.
Of course it rolled backward! There is no hydraulic pressure maintained in the brake system while the car is off! That's what the mechanical (as opposed to hydraulic) parking brake is for. For parking. Use it or next time you will roll back hit someone's car, or worse cause an accident. The brake system isn't pressurized until a couple of seconds after you start the car. As soon as you clutched and put the car in neutral, the transmission is no longer holding the weight of your car. BTW, you are screwing your transmission by putting it into a bind and forcing it to hold the weight of your car on a hill rather than having the brake engaged which it is designed for. Is this your first MT?
^ he is right.
Old 02-16-2010 | 09:19 PM
Beer Magazine's Avatar
Beer Magazine
Originally Posted by Dvit
^ he is right.
No he is not. The brakes 100% hold pressure with the car off. If it doesn't there is a leak or a ton of air on the system. Car on just gives you brake assist to make it easier. You think there is no steering with the car off, lol
b2autodesigns
Brakes/Suspension
128
03-24-2018 07:44 PM
warpeacelove
10-28-2015 02:59 AM
ZachThomas
09-03-2015 01:40 PM
dlc1988
09-02-2015 09:40 AM
TheLocNar
08-16-2015 07:14 PM
Quick Reply: so my brakes wouldnt work? the hell
