VDC, ABS, Slip Lights on. Tried solutions and now dealer wants $120
I searched and read all the threads about the VDC, ABS off, Slip warning lights all staying on. Recently, in southern california, we've had a bit of rain and after driving thru some flooded streets, all 3 of those lights have been coming on.
I checked brake fluid and topped it off. I also reset the ECU with no luck.
It seems that the lights only come on if the steering wheel is rotated past a certain point.
Since my car is past 60k miles, and leaving the car at the dealership, they want $120 to fix these "fault codes". Seems like I'm getting ripped off for some things that are just going to be reset.
Any help or advice?
thanks in advance.
Any help or advice?
thanks in advance.
How is your tire wear? I notice in my 350Z, that when my tires have pretty much worn down to slicks, a certain corner on my commute will cause the SLIP and VDC light to turn on (not sure about ABS light). Restarting the car will make all the lights turn off, but every time I hit that corner they turn back on again.
-D'oh!
-D'oh!
Hmmmm, I think your Maf sensor got wet, or another sensor got wet somehow. I had the EXACT same problem after going through a carwash one time. Got home, pulled the Maf sensor and voilia! There was some moisture on it. Dried it with my air compressor, reset the ECU and it was good to go.
Tire wear is still okay, checked tire pressure just to make sure also. My G has tanabe lowering springs and sits on 20's, but it's been okay wayyyy before the rain came. Just got my 60k service done a few months ago and now I'm at about 63k.
StopTheExcuses - I am also using Stillen Intakes. The MAF is on there correct?
Update: Just called dealership, it is almsot noon and my car has been there since 2:30 pm yesterday, and they still have no update for me. Not happy at all. Sure, I am in a loaner, but not excited at all with this waiting game.
Ahhh, yup. That HAS to be ur culprit. When I had it happen to me, I was using Injen CAI. So, somehow, you had just a little water get into the sensor. I'm 99.99 percent positve that's what has happened in your case. It does not take much to cause it to throw the cell, abs and slip lights on these cars. Take your maf's out and blow them dry carefully with an air compressor and you wil be fine. Don't spend that $120!
As of a year or so ago, Kragen/Pep Boys/Autozones stopped carrying ODB code readers, as from what I was told, a law was passed against it due to a lot of small mechanic shops complaining about the bigger name stores allowing the access for free.
I picked up my car yesterday, and paid $60 for a diagnostics fee.
The dealer told me that they took out the left brake sensor and it seemed I needed a new one. They swapped the right with the left and the problem went away. They proceeded to put the sensor back to the original side and it seemed the problem went away. I got to walk away paying $60 bucks for a diagnostic fee, and the sense of MAYBE it coming back again. Somehow I feel that they just checked some codes and reset em. Probably last time I go to that dealership.
If you then take it to a shop they are not going to take their word for it, and will charge you a diagnostic anyway around here.
