adjust rear camber/toe without drop
anyone have a how-to for adjusting the rear camber/toe even if I didn't drop my car? I just had my 2 rear tires replaced, and now it looks like the camber and toe is jacked up on both wheels. Wouldn't want the tires wearing out since I dropped some serious change on them...
Why not just get an alignment and have the pros do it?
Don't see changing out tires would screw with your camber and toes. Did something go wrong?
Post a pic.
__________________
Post a pic.
__________________
i did buy my car used, so the previous owner must have had the rear alignment done for the tires that were replaced. after putting on my new tires, i can see that there is an obvious amount of negative camber and toe-in on the wheels. it looks like the car is dropped from behind, although it isn't.
yeah i will call around to see if a shop will just do a rear wheel alignment to save some money, and so i don't feel anxious about new tire wear...
I think they have to align all 4, around 80-90 bucks.
Maybe you can trade with some night elf mohawk grenades.
__________________
__________________
i didn't say that the alignment got messed up through the tire install (unless the mechanic decided to purposely do such a thing), i just said that both toe and camber now looks off with the new tires on, so i am just inferring now that an alignment was done on the rear to accommodate the tires replaced. i just want to make sure that my new tires don't wear out prematurely from the current wheel alignment, and was wondering if anyone had set camber/toe on the rear themselves, without a kit, which I don't think I need since I'm still at stock height.
I just want to make sure that my new tires don't wear out prematurely from the current wheel alignment, and was wondering if anyone had set camber/toe on the rear themselves, without a kit, which I don't think I need since I'm still at stock height.
It is possible to do an alignment yourself, but as I recall from when I installed my rear camber/toe kit you will only be able to alter toe with stock equipment...but I would assume getting it right is very difficult w/o proper equipment.
And if you are saying that you think it is possible that the alignment is different from changing tires, you should probably leave the alignment to the professionals.
been working on cars for cars for about 6 years now, though i never did try to set the alignment on a car myself. I figured there would be a way to save money and just try to tweak the rear alignment on my own though, since I was messing through the G37 FSM and it mentioned something about adjustment bolts on the front and rear lower links on pages RSU-6 and RSU-7. again, i didn't say the alignment was altered (not that i know for sure since i wasn't at the shop while my tires were replaced), but the rear wheels just don't look 0'd (is that the term for 0 camber and/or toe) or right after the tire install. what the shop guy did show me was that the tires that were on before (stock RE050's) did have uneven tire wear, tread was worn on the inside of the tires while the rest of the tread looked fine. maybe the previous owner had the car dropped before I bought it, I dunno too much guessing at this point, and I just want to avoid premature tire wear. Still gotta call around to see what shops can do for me
