How to take off rear suspension
Download the service manual here. It has what you need and the torgue specs. It will give more accurate answers than what you will find on the forum. A big advantage of the DIY is the pictures the forum members post. I use both.
Infiniti Factory Service Manuals
2 10mm nuts on the upper side of the shock
1 long bolt on the lower side of the shock, should be size 17mm. you'll need a socket and a wrench to hold the other end to prevent it from spinning.
1 17mm bolt that holds the spring perch.
easy.
easy.
Majeed Bader
10-08-2015 10:52 AM
WillCo1
09-01-2015 11:31 PM
