Can I get a G37S suspension on a G37x?
Hello everyone,
Newbie here considering buying a G37. I test drove both the G37x and G37S yesterday.
Since I live in the snow-belt and wanted the G37x, I drove that first. Liked the engine, but the suspension was too soft for me, as the car understeered everywhere. Note that my current car is a Subaru WRX with a stiffened suspension so I am willing to give up some comfort for the right performance.
The salesman had just joined Inifiniti and said that there was a sport package available, but they only had a G37S 6MT available, and would I like to take that out for a spin? So I did, and I absolutely loved it. Great turn-in, strong brakes. It would be an ideal car if I lived in a warm climate. But I was more than willing to buy an automatic G37x with that suspension.
So after the test-drive the salesman realized his error and stated that the G37x does not have a stiffer suspension with its sport package. That soured me on the deal.
But I am wondering how difficult it would be to retrofit a stiffer suspension on the G37x? Is it just a difference in sway bars? Or is it more involved than that?
pnk
pnk
It probably can be done. The X rides a smidge higher than the standard and sport versions. Call riverside infiniti. I don't think there is a difference in sway bars or bushings, just in springs/shocks. Also, the S has sticky summer tires and the X has all seasons, probably a lot less grippy.
for the x model, you can switch to eibachs... don't believe you can put the S springs on since the shocks are different.
The sways are also a bit different and there are no current aftermarket alternatives.
You can use just about any spring on the X that would normally work on the S model. The shocks are different, and you must use the X shocks (the fronts have a fork to clear the front axle).
The S springs would be a better match for the stock shocks than Eibach. Using aftermarket springs will typically decrease the life of your shocks (lower/stiffer causes excess wear on the shocks). Since the stock "S" springs are not as low, and not as stiff as the Eibachs, they should allow your shocks to last longer.
Sway-bars are different to clear the AWD components, and cannot be used. The only thing that can be used is the springs, and any spring will work (just depends on how low you want to go).... There are no sway-bars or shocks out for the AWD. BC is working on a set of coilovers.
Gotta love people posting that have no clue....
http://eibach.com/cgi-bin/htmlos.exe...86269700011090
note "G37, Coupe, 3.7L V6
(Incl. "S" & Active-Steer. Exc. AWD.)"
yes I agree. I guess eibach an H & R made different part numbers for the AWD models instead of just selling the same part as the sports because they were bored.
What's your point? I think everyone agrees that he could use H&R or Eibach, or any other 2nd Gen G35/37 spring for that matter. Your the one that said S springs would not work, and that is strait up wrong. Not sure what else to say.... There were 3 posts in this thread and all contained some piece of false information.
Eibach did it because of the different rebound and compression of the AWD shocks. Will some springs work better than others? Yes, probably so. I stand by my comment that the S springs will allow the shocks to last longer than any Eibach alternative.
Thank you all for your replies. It looks like the suspension mods will be more involved than I would like. I am very comfortable with swapping out sway bars and I have a pretty good idea of what they can accomplish, especially since most sway bars are adustable.
I am reluctant to go down the path of buying a G37 and replacing the springs as I just don't know how the vehicle would feel afterwards. The G37 is a great value, but it's still a decent chunk of change, and I want to make sure it turns out right. If I happen to find someone who has already a G37x with a modified suspension that I could ride, I would reconsider it.
pnk
pnk
I just tried building a G37X on Infiniti's web site, and here is what comes up when I ask for info on the sport package.
• Split 5-spoke 18 x 7.5-inch aluminum-alloy wheels with 225/50R18 (front) and 18 x 8.5-inch 245/45R18 (rear) summer performance tires (RWD models) • Split 5-spoke 18 x 7.5-inch aluminum-alloy wheels with 225/50R18 all-season performance tires (front/rear) (AWD models)
• Sport brakes with 4-piston opposed front calipers with 14-inch rotors and 2-piston opposed rear calipers with 13.8-inch rotors (RWD models)
• Unique front fascia and side sills
• Solid-magnesium paddle shifters (not available on G37 Sport 6MT)
• Front sport seats with manual thigh extension and driver’s power torso and thigh support adjustment
• Unique sport stitching on steering wheel and front seats
• Aluminum pedals and footrest
• Sport-tuned suspension (RWD models)
• Viscous Limited-Slip Differential (RWD models)
Most of the goodies are reserved for the RWD models unfortunately.
pnk
pnk
pnk
pnk
Just as an FYI, the stock-S springs will be a very mild drop, the Eibach's will be slightly more, and the H&R's will slam it pretty good. The Tanabe springs I saw on the X, had an uneven drop. From a handling improvement standpoint, all will stiffen up the springs a bit. It is hard to compare the Eibach springs because they are progressive springs and don't have a specific spring rate. None of the others are much stiffer than the "S" suspension.
That is the case - no tighter suspension and no big brakes that come with the RWD S version. If the XS version came with these things it would make my buying decision much simpler. I guess you can do it after the fact though with the S springs?
I drove an 08 xS for almost a year. IMO in the real world the stock suspension on the xS is fine. I never ever had any issues with the suspension. If I still had my xS I would of left the suspension as is and upgraded the brakes. If you plan to use your G on a track upgrade both.
