G37 lowering database
#46
#47
#50
Vehicle: 2012 G37 Sedan - Journey
Supension: Swift RWD springs
Height: Front 27 even / Back 27 even...literally
Wheels: factory 18" package (19's to come)
No camber kit needed.
Update on new wheels:
Stance SC-6
Front 20x9 +35 255/35
Back 20x10 +42 275/30 w/3mm spacers
No rubbing
Stance SC-6
No rubbing
#51
Vehicle: 2013 IPL Coupe 6MT
Suspension: KWv1 coilovers, SPC front/rear alignment kit
Ride Height: 26.5" front, 26.75" rear
Wheels / Tires: OEM IPL 19" wheels, 225/245 tires
Do you rub? Nope
Is your drop even side to side? Yes
Do you rub? Nope
#52
- 2009 Sedan AWD
- Suspension: Swift Sport Springs
- Ride height: 26.75" Front 27.5" Rear
- Tire/Wheel: 20x9 +35 245/35/20 Front - 20x10.5 +45 285/30/20 Rear
- No rubbing, No camber kits needed.
- Front is lower than rear [& I like it ;]
#53
most of these posts with the prokit seems to shows more than that.. particularly several of the sport model..
ill be adding my info as soon as my eibach install is complete and settled.. just did the fronts today
#54
..so the advertised 1.2 and .8 drop from eibach for the coupe is conservative..
#55
its only been a day but have placed over 100 miles on her.. so far its settled to 27" in the rear but the fronts are uneven...
the driver side to be 26.875" whereas the passenger side is 27.25"
measured in three different places that looked level.. tire pressure the same..
im guessin due to my weight has helped it settle quicker driver side... would a blown strut provide uneven height...
#56
Has anyone bought the swift springs Spec-R's?
They sound like a nice mod to me. Can I get some feedback on this guys?
#57
Stance SC-6
No rubbing
Stance SC-6
No rubbing
#58
Coupe
Tein S-tech w/ SPC rear camber bolts
Before and after measurements will be posted after it settles for a week
19x9.5f-11r - No idea on offsets.
Rubs on obvious bumps and dips but waiting on alignment still
The corners seem level but I'll measure when its done settling.
#59
'08 Sport Coupe
Suspension: Tein Mono Sport coilovers EDFC Active Pro
Ride height: 26.0" Front 26.0" Rear
Tire/wheel size: 19"X8.5" 225/45/19 Front - 19"x9" 245/40/19 Rear - Stock Sport wheels wrapped in Michelin PSS.
Alignment hardware: SPC Camber arms. Stock toe bolts.
No rub.
Level all around.
No rub.
Level all around.
