G37 lowering database
Old 07-08-2009 | 03:05 PM
TIMMAY's Avatar
TIMMAY
hahahahahha.. ride height: 53 fingers front, 55 fingers rear hahahahha
Old 07-08-2009 | 03:13 PM
myk1013's Avatar
myk1013
-2008 Coupe
-Eibach ProKit
-26.5" front and rear
-Volk GT30's 20x9.5 f / 20x10.5 r
-Yokohama S.Drives 255/35 f and 285/30 (rear rubs on big dips and bumps)
-Even drop, but not when I'm inside the car. he he he
Old 07-26-2009 | 02:13 PM
TheCutter's Avatar
TheCutter
2008 G37S coupe
Suspension: KW Variant 3, no camber kit
Ride Height: Rear 25 and 7/8, Front 26
Rear Camber: -2.6
Front Camber: -1.9
Wheels: Volk Racing GT30
Front: 19" 9.5"
Rear: 19" 10.5"
Offset: sorry, dunno
Tires: Toyo T1R's
Front: 245/40/19
Rear: 275/35/19
Rubbing: only on the most extreme bumps
Handling: Fricking awesome
Note: will likely purchase front and rear camber kit at some point
Old 10-19-2009 | 07:08 PM
I've been rubbing in the rear even with the fender liner trimmed when I hit on some large dips or bumps at high speed, so I'm going up to raise it up to 26.75" rear and leave the front alone until I test it out.
Old 10-20-2009 | 05:57 PM
GOTTIITTOG's Avatar
GOTTIITTOG
My only worry about a post like this is 95% of the people on here have coupe's vs sedans....and my worry is true...All thats posted is coupes. How about we have 2 threads, one for each model.
I know i have been looking for springs for my sedan and really there isn't any clean info on whats needed and the info and maybe pics on teh cars for each spring...
Jim Bob (09-24-2016)
Old 10-27-2009 | 05:23 PM
Sedan guys are not excluded, you are welcome to post up your sedan specs to help out all sedan owners. I don't see why you'd need a separate thread because you can easily state whether you have sedan or coupe, but if you want to start a separate sedan thread be my guest.
Old 07-25-2010 | 04:55 AM
cereal2k's Avatar
cereal2k
Mr. Drop it like it's hot
Why isn't this a sticky?
Old 07-25-2010 | 04:56 AM
cereal2k's Avatar
cereal2k
Can it be a sticky?
Old 07-27-2010 | 11:38 AM
Ahujadaddy's Avatar
Ahujadaddy
def a good, useful thread. Thanks J
I have had eibachs since around when they first came out for our car, will measure and post later. Thinking about getting some Tanabe coilvoers though. n00b when it comes to coiliovers so will have them installed, not sure how or what to set the initial height to.
Seems somewhere in the mid to upper 26" range is good. Hate the stock look where the front is so high up, and just want to avoid that. Question though....
ANYONE know the approx stock ride height? i took before and after pics with eibachs and measured but now don't rmbr the stock height and didnt post that. I would guess something like 28" front and 27.5" rear?
Old 07-27-2010 | 12:30 PM
cereal2k's Avatar
cereal2k
Th stock ride height is posted in a bunch of threads. I posted one in the vertforum when I was researching dropping the vert.
Old 07-27-2010 | 12:43 PM
cereal2k's Avatar
cereal2k
The ride height details are on the attachment and also in the 2008 factory service manual
https://www.myg37.com/forums/g37-con...s-instead.html
Old 07-27-2010 | 12:57 PM
Harley'sG's Avatar
Harley'sG
For the losers who measure distance in "fingers":
Please put an actual measurement of your ride height from the ground to the top of the fender opening in inches. "1 finger" or "2 fingers" is a measurement of how far you get on a date with your slutty girlfriend, not a scientifically accepted measurement of distance. Get a tape measure or yard stick please! Thank you.
Amended my setup info int he first post.
^^^lol!! Not everyone has man hands so...
Coupe
Eibach Pro Kit
Front = 26.5 inches Rear = 26 5/8 inches (to be exact)
Stock 19's with stock tire sizes
No rubbing
Drop is even on both sides
Old 07-27-2010 | 01:08 PM
philter25's Avatar
philter25
Originally Posted by philter25
'09 Coupe
Suspension: eibah prokit
Ride height: 26.75 front, 27.25 rear.
Tire/wheel size: stockies
no rubbing at all....
Drop is pretty even side to side, varies by 1/8-1/4 inch some days depending on weight in the car, fuel, tire pressure, etc.
MyG37 - philter25's Album: Eibach Springs
Update:
Suspension: Tanabe NF210 front / Eibach Prokit rear
Ride Height: 27 1/8 front and rear.
Tire / Wheel: Stock and stock
No rubbing at all. I wanted a dead even fender gap and my eibach's were almost at 26.5 in the front and 27.25 in the rear, so 3/4 of an inch started to bother me so I put the tanabe fronts on. Dead perfect.
I also like the stock wheels and didnt like the tucked in look of the Eibach fronts.
https://www.myg37.com/forums/brakes-...ach-rears.html
Old 07-27-2010 | 01:09 PM
  #29
philter25's Avatar
philter25
Correct. My measurements were exactly that.
Old 07-27-2010 | 01:50 PM
  #30
Exact coupe stock ride height has been added to the first post (taken from the '08 FSM).
