Stoptech and Rotora OEM Replacement Rotors
Old 05-15-2009 | 09:09 PM
  #46
Lastchance's Avatar
Lastchance
I'm still waiting for the Stoptech rears and haven't run my car very hard yet with the new Project pads...
Old 05-19-2009 | 12:49 PM
  #47
KAHBOOM's Avatar
KAHBOOM
Super Moderator of Pwnage
Originally Posted by skaterbasist
I'm not sure if you G37 folks are aware of this, but a vendor at G35driver.com is almost done with their 2-piece rotors. They are, according to them, 10 lbs LIGHTER PER ROTOR than the stock rotors (these stoptech/rotora rotors should weigh about the same as stock). This is a huge difference.
Along with the reduction of unsprung weight, 2-piece rotors are better when it comes to heat and holding up against hard track use. 2-Piece rotors are the only way to go if you really care about performance!
(This is not the final production version)
This will ikely be my next mod
Old 05-19-2009 | 12:57 PM
  #48
HamstersG's Avatar
HamstersG
There are some good prices on their web-site for some things. Just looking at the other brake prices, I would guess $1,000 to $1,500 for a set of 4 for the G37S?
I did see that they zinc coat all their rotors which would be a plus.
Old 05-19-2009 | 05:26 PM
  #49
KAHBOOM's Avatar
KAHBOOM
Yep that combined with the lighter weight would make it worth the few extra hundred dollars.
From what I've read, according to my memory (someone correct me if I'm wrong), for every pound that you save on un-sprung rotational weight such as wheels, brakes etc its the equivalent of saving 2.5 to 4 lbs (depending on the part) of sprung weight on the chassis.
Old 05-21-2009 | 12:11 PM
  #50
WildWes's Avatar
WildWes
Picture of Rotora Front and Rear Drilled/Slotted rotors.
Should I powder coat the calipers in red with Akebimbo??? lol.
Old 05-21-2009 | 01:55 PM
  #51
HamstersG's Avatar
HamstersG
Naaa....the lettering would be too small.
Old 05-21-2009 | 02:15 PM
  #52
xlack's Avatar
xlack
hehe Akebimbo is cute. no offence.
SBG37
03-12-2021 04:16 PM
b2autodesigns
Brakes/Suspension
128
03-24-2018 08:44 PM
Digilog
09-18-2015 02:53 PM
KAHBOOM
08-25-2015 12:05 PM
RoyalG37
08-11-2015 01:21 PM
