suggestions for suspension improvement
Hi, I have a non sport g37. I would like to improve the body roll without sacrificing ride comfort. Can someone recommend which parts I should get first for the most improvement and bang for the buck?
Eibach Prokit Lowering Springs
$229
SPC Front Camber Arms
$369
SPC performance Rear camber kit
$215
hotchiks front and rear sway bar kit
$359
Rear Latteral Brace MShape
$139 *only fit stock exhaust
Gtspect Rear lower tie brace
$89
GTSpect 6 point Rear subframe Brace
$359
GTSpec G37 Fender Brace
$237
GTSpect Front Tower Brace G37
$199
GTSpec Front 2 Point Subraframe reinforcement brace $89
GTSpec front 4 point Ladder Brace $199
GTSpect front subframe tie brace $149
$229
$369
$215
$359
$89
$359
$237
$199
Every one of these is going to be a compromise on ride comfort to some degree. You don't need front or rear camber kit unless you are lowered. Stiffening your car's frame or suspension will do just that - stiffen the ride as well.
That being said, of the choices given I'd go with the lowering springs FIRST. Form there you can determine which direction you want to go next.
If it were my car and I had money to do all of these, I'd get them in this order:
Eibach springs
SPC/Eibach rear camber kit (front probably isn't needed)
Hotchiks front and rear sway bar kit
GTSpec 6 point Rear subframe Brace
GTSpec Front 4 point Ladder Brace
GTSpec Front subframe tie brace
GTSpec Rear Latteral Brace M Shape
GTSpec Rear lower tie brace
I wouldn't get the GTSpec Front Tower Brace because of the poor fitment issues (unless you do a DIY hack up of the engine cover mounting) and it's been posted that they don't intend to change it so that it doesn't rub the underside of the hood.
My .02
Eibach springs
My .02
Hm.. Gtspec recommended the rear latteral brace m shape and rear lower tie brace and the 6 point rear subframe for maximum difference.
I'm kinda worried about dropping my G, n having to deal with scraping.. I wonder if I should just get the sways and call it... install would prob be $150-200?
An Eibach or Tanabe drop will not scrape easily; certainly not under most normal conditions. I've only scraped a couple of times on very steep driveways that I didn't take at enough of an angle. Coilover guys who are slammed are the scrapers.
Sways are very easy to install yourself in your driveway with the most basic of tools. Not hard at all. See the DIY on it.
I agree with betty. Start with lowering and then get the sways. I have a non sport as well and the eibach springs coupled with the hotchkis sways is perfect. Handling is much better and the ride quality hasn't suffered much at all
A drop with Eibach or Tanabe can still be aligned to close to factory specs without any kit. With the rear SPC kit, you can align it perfectly (I did with Tanabe's) . Yes, stiffer/shorter springs do make you shocks wear somewhat quicker, but a small drop like these won't damage them quickly. Nobody can say how much accelerated the wear is because nobody has enough miles on their car yet to make that determination. I'd guess you can still get well over 100K miles before noticing any ill effects, but that is just a guess.
Will a non-sport with eibach drop + hotchicks sways have the same suspension as a stock sport g37? Slightly better worse?
misc
29
05-24-2023 03:57 PM
