Help SPC Front Camber Kit Rattle
#181
Yes. Using the SPC instructions, set the caster where you want it and then slide the camber/caster adjuster all the way toward the outside of the arm for initial install.
And study the caster instructions very closely to make sure you set it the right way and were you want. You would think that the arms would come with it set at zero but mine did not.
#182
#183
Updated Info from Jeff @ SPC
The testing of the 72130 arms for the 2008 G37 Coupe has given us the following results:
- the arm will provide up to a 1.5deg positive camber change
- vehicles dropped 1.2" (ie Eibach Pro Kit) can anticipate a camber correction approximately to OEM nominal spec.
- vehicles dropped more than 1.2" can expect camber correction not to exceed 1.5deg, which may leave the camber alignment measurement closer to the negative end of the spec range.
- OEM bump stop must be used for all applications
- no additional bump stop washers were used with the Eibach kit and no interference issues have been reported.
- it may be necessary to position the ball joint in the -0.5deg caster position before adjusting camber. This adds a bit more clearance
between the arms and the fender well.
- vehicles lower than 1.2" should use the bump stop spacer washers supplied with the arms. Additional spacers will be available for sale if needed to ensure the bump stops are bottoming before the arm
#184
Sounds like we need a new vendor to start making these.
#187
On Eibach. No issues. Perfect alignment.
I don't see any way to improve on the arm given the geometry of the G37 and the fender design. They could shorten the camber/caster piece by removing the caster adjustment, but a little negative camber is needed to correct the alignment to spec as you lower.
#192
Either you're being a smartarse or you don't pay attention... my numbers are there for you to see in previous posts...
I personally couldn't care less if these found their way onto your G, I'm just trying to help the community out.
#193
Have no idea what SPC is doing on returns. If I was you, I would call Andy. If you are on just a mild spring drop, I am sure you could get them exchanged with Andy and/or SPC if you wanted to go with the shorter arm. To be clear, I am 100% fine with the shorter arm with my set-up and have no plans to remove them.
#194
SPC is doing a direct exchange for the new arms. Email them at custserv@specprod.com with your name/address/phone and they will email you a UPS label. Once returned, they will send the 2007-08 G35 sedan arms.
http://www.spcperformance.com/PROD_D...d2=72130&cmd3=
