After alignment specs after KW drop, or should I say SLAM!!!
03-14-2009 | 12:09 PM
Suspension:
KW V3
SPC rear camber kit.
I have to order the following..
SPC front kit
Toe bolt
AHHH!!!!
03-14-2009 | 02:21 PM
Your car is F'd up!
How low are you running your car? How many tires have you eaten trough like this? You didn't get the toe bolt with your rear camber kit?
03-14-2009 | 02:26 PM
Quote:
Originally Posted by
Your car is F'd up!
does toe bolt come with rear SPC camber kit cause i got the rear spc kit in my room but havent open the box yet. Getting the front soon
03-14-2009 | 02:30 PM
Dude.. How did they go from a -2.0 to a -3.0 on the rear left when its range is [-1.8,0.8]? They took it further out of spec!!! Are you sure you have a rear camber kit? Your toe is spot on in the front and rear, but camber is out of spec in both front and rear.
slamming it will look hella goooooooood, but then the bottom of your car will go bye bye =[
03-14-2009 | 03:02 PM
aliiin
so will the tires
03-14-2009 | 03:06 PM
Yep yep. SPC Rear kit doesnt come with toe. Hes SLAAAAMEDDD. Take a pic.
03-14-2009 | 03:41 PM
I spoke to Andy and he said that it did come with a Toe kit..
03-14-2009 | 03:43 PM
03-14-2009 | 04:29 PM
+1 on taking a pic of that slammed drop
03-14-2009 | 05:08 PM
03-14-2009 | 06:15 PM
I received toe bolts in my Eibach rear camber/toe kit. It's the same as the SPC (PN 5.72260K).
03-24-2009 | 07:14 PM
Ok, so I took it back to the alignment rack, and they said anymore adjustment to the camber would result in a negative toe.
Am I hearing a crock of ****? or is this true?
03-24-2009 | 10:14 PM
I am assuming not true since you have the rear kit. BB might know more . . .
03-24-2009 | 10:20 PM
such n00bs. lol
The rear camber kit can be bought with OR without the toe kit. Technically the toe kit is seperate.
