After alignment specs after KW drop, or should I say SLAM!!!
Old 03-24-2009 | 10:38 PM
Originally Posted by xyz
I am assuming not true since you have the rear kit. BB might know more . . .
Sounds like complete BS to me because they are completely separate entities, but perhaps it's true. I don't know. I cant say for sure but I tend to not believe that.
Originally Posted by STOOF
such n00bs. lol
The rear camber kit can be bought with OR without the toe kit. Technically the toe kit is seperate.
Yes, technically they are different parts, however I haven't seen any of the vendors here selling the rear camber kit without the toe bolts that I've noticed. Have you?
Old 03-25-2009 | 01:22 AM
NeverBoneStock's Avatar
NeverBoneStock
I was told the SPC toe kit doesnt allow any more adustment over the oem ones.. Is that true ???
Old 03-25-2009 | 02:20 AM
No. You have to dremmel the hole out about 1/4" wider in the rear crossmember so it can move that much further. You can adjust more than stock.
Old 03-25-2009 | 02:39 AM
G_Thang's Avatar
G_Thang
Originally Posted by pfizzle
Ok, so I took it back to the alignment rack, and they said anymore adjustment to the camber would result in a negative toe.
Am I hearing a crock of ****? or is this true?
I havent installed my kit yet, but this is possible. Your moving about a central point. If you reach a certain deflection on one axis, it will eventually start to affect other axes as well. The center of the wheel is moving about on an xyz axis. If you max x out, y will start deform since z isnt adjustable (with OEM links). I'll be able to tell you definitely later this week, when I install mine. Knowing what I know about suspensions, this is totaly plausible. I looked at your specs and they were pretty far off. You must be really slammed? Your SAI (steering axis inclination) is even out and thats hardly ever out.
Old 03-25-2009 | 11:02 AM
w0ady's Avatar
w0ady
um thats really not that bad. im running 0 toe with about -1.5 to -2 camber all around with my eibach drop.
Old 03-25-2009 | 11:59 AM
pfizzle's Avatar
pfizzle
Some settled pics..
Old 03-29-2009 | 09:15 AM
myk1013's Avatar
myk1013
^ok, you are officially the most slammed G37 in here.
shiet that's LOW!!
Old 03-29-2009 | 03:45 PM
G_Thang's Avatar
G_Thang
How are your tires wearing with that much negative camber? How many miles do you have on them? I guess I'm going to run OEM upper arms until either SPC redesigns them or someone else comes out with some (besides Stillens for $1100).
Old 03-30-2009 | 03:03 PM
Ivoidwarranties's Avatar
Ivoidwarranties
That is almost too low for my taste.
Old 03-30-2009 | 03:25 PM
TimG37S's Avatar
TimG37S
That's beyond reasonable...That takes away from the handling completely. I don't see the point of making something handle worse.
I'm sure it's still a head turner though....
rk325
10-13-2015 02:51 PM
faze2988
10-07-2015 01:05 AM
BurtoN86
09-30-2015 04:32 AM
Murkr
09-28-2015 11:45 AM
Allboutcali
09-26-2015 04:43 PM
