Help G37S factory spring rates?
Hey guys, been doing some searching to find out what the Factory "S" springs rates are but not really coming up with anything. Thought I would ask here to see if I could get any info.
Anyone know?
Thanks!!
Anyone know?
Thanks!!
I was looking into this also when before I lowered my car on Eibachs to make sure that I wasnt going backwards on the spring rate.
I was able to find out that the Tanabes springs are better than the non-sport springs but not the Sport springs - per Tanabe.
From Eibach -
" The springs were designed off of the base model. If the sport model is lowered from the factory compared to base model then you would have to subtract the amount lowered from ours.
fronts 6388.001: 228 lbs/in up to 548 lbs/in
rears 6388.002: 371 lbs/in up to 531 lbs/in "
hope this helps
From Eibach -
hope this helps
Tanabe are supposed to do keep the ride quality based on the stock spring rates.
If you really want to know it measure it yourself. Compress it 1 inch in a press and measure the deflection.
How do you measure progressive springs?
Springs follow the equation F = kx, where x = the deflection or the spring, k is the spring constant and F is the force applied to the spring. This equation tells you its linear. Progressive springs use multiple springs to achieve an exponential spring rate. You'll have to measure the individual spring rates. I'd doubt if any coilovers made for the G37 have a progressive spring rate.
I try to educate ppls when they ask questions and I know the answer. I give them real answers and not some biased bs because I lack the knowledge.
How about you take the ******* remark and take it somewhere else. Obviously the OP is not an engineer and/or doesnt want to remove his stock springs to compress them. Thanks for the equation though.
If you are an engineer than you should be able to figure out that I am not a "dude".
You cant tell from the looks of a cars stance if springs are linear or progressive. At least to my knowledge. All springs used in automotive suspension applications are linear. When a spring is compressed (or in tension) so far it becomes nonlinear, its behavior becomes unpredictable and it susceptible to metalurgical failure.
Unlike you, he is capable of working on his own car and reqeusted the information.Since no one else answered I did. Hate me becaulse I have the knowledge. I care NONE!!!
