Alignment Specs after Eibach/SPC Camber Kit
Old 12-09-2008, 07:03 PM
MaxToTheG37
Super Moderator w/ Boost
MaxToTheG37's Avatar
Arrow Alignment Specs after Eibach/SPC Camber Kit
Just wanted to post up the Specs... HAd to get keep the camber at 2.0 so the toe would be ok and not eat my tires... Its a big relief now since my last tires were ate up in about 3 months...
and A lil Negative Camber never hurt anyone
Heres the pic of the specs....
btw... got the Eibach Kit from Andy@HPAuto... Great PRICE!
Now Im ready for a Front Kit ... hurry SPC...
Old 12-09-2008, 07:09 PM
Did you install the rear camber kit yourself? I just got mine in and haven't put it on yet. I was hoping to get the rear down around the -1.3 to -1.5 range. Over 2 will still eat rear tires.
Old 12-09-2008, 07:21 PM
Kidcane
Florida G Club
Kidcane's Avatar
^^I just put mine on last week and thats about where I am at but now I rub every once in a while so I may have to dial back in a bit.
Old 12-09-2008, 07:30 PM
MaxToTheG37
it has to be that negative due to the Toe being out bad... you would rather run a lil negative camber than Toe because Toe will chew... bad...
oOmikeyboy
oOmikeyboy's Avatar
Mine was done with the SPC camber kit. heres the results for the REAR w/ htechs. Strange, the guy couldn't get my Caster adjustment on the front anywhere near spec without a kit, he says.
MaxToTheG37
No i didnt install it myself...local shop...
Old 12-09-2008, 08:53 PM
vINCe_Inc
vINCe_Inc's Avatar
what is the stock camber in terms of degrees for the g37s ?
Old 12-09-2008, 08:56 PM
jedmonds
jedmonds's Avatar
Thanks for the info max, I was considering swapping out the front springs for eibachs, but I think I'll wait to the spc front camber kit officially comes out.
Old 12-09-2008, 08:59 PM
MaxToTheG37
my fronts are ok... tires are wearing pretty even.... fyi
Old 12-09-2008, 09:00 PM
MaxToTheG37
the stock specs are in the upper left hand and right hand of the colored blocks...
Old 12-09-2008, 10:39 PM
oOmikeyboy
oOmikeyboy's Avatar
Hey max, noticed your front caster specs are green, how did they do that??
edit: nevermind, i think mines normal too??
Old 12-09-2008, 11:21 PM
MaxToTheG37
yea the way caster was explained to me was they both need to match and your good...
Old 12-10-2008, 02:08 PM
Ahujadaddy
Ahujadaddy's Avatar
lol, nice Max
Old 12-13-2008, 08:44 PM
xref
xref's Avatar
Did they have to make the hole bigger when they installed the camber kit? I'm getting mine installed today. Thanks!
Old 12-14-2008, 10:21 AM
MaxToTheG37
yes they drill out the hole a lil and it gives you more adjustablitly...
Quick Reply: Alignment Specs after Eibach/SPC Camber Kit
