Help with camber kit please.
I tried to install the eibach camber kit when I was installing my coilovers, but for some reason the kit did not fit on my car. The hole on the aftermarket camber kit was smaller than the one on the stock camber arms and it would not fit like it should.
I'm not sure if I got the wrong camber kit, or if I installed it incorrectly. I can post the model number up later, but if someone has a pic of the camber kit, or even a pic of the stock camber arms I would like to see it.
Thanks,
Tom
Thanks,
Tom
Do you have 4WAS? If so then it won't fit. Here is the part number for the correct SPC camber which is what Eibach uses but relables it: 72260 From what I have been told this only works for the none 4WAS G37s'
It is the camber kit for the 07+ Infinit Sedan. If you got the G35 Coupe and older sedan model then it won't work. If you really need pics of the stock cambers, I can get it to you but I don't have time right now to do it.
5.72260K
It is similar to yours, but it had a 5 before it, and a K after.
The camber is on my car so it is going to be hard to get a pic. I can try to get you a pic in a day or so if that works for you. I should be able to take a pic tomorrow. Just bump this again if you didn't get the info by then.
I would like to know the size of the hole that bolts onto the subframe if you can get that.
I talked to eibach today, but I need to call them after I can take a look at it again, but I have had no time to look because of work.
optikol
01-28-2016 07:31 PM
