Attention All BC Racing Coilover Guys, Check your Rears--Possible Install Error...
Old 06-24-2008, 02:21 AM
  #196
sahiwal007
sahiwal007's Avatar
Originally Posted by Xander
Now my rear is so low that you can pretty much only see the top of my rim.
wow, i would love to see a pic of that
sahiwal007 is offline
Old 06-24-2008, 02:38 AM
  #197
Xander
Xander's Avatar
sorry about it not being resized
http://i29.tinypic.com/n4b5gl.jpg
Last edited by bboysteele; 06-24-2008 at 02:40 AM. Reason: Putting the image tag in so the pic shows in thread
Xander is offline
Old 06-24-2008, 02:40 AM
  #198
finagle69
finagle69's Avatar
yeah, that looks pretty dumped.
did you set the height of the shock per Pete's instructions?
finagle69 is offline
Old 06-24-2008, 02:18 PM
  #199
symalik
symalik's Avatar
Mine is a bit higher that that, its all the way raised almost. But it still rubs. The shocks should have no effect on the height, just the stability of the spring, which I can tell mine is definitely moving a bit. The tire is rubbing the fender liner, there is not even room for a finger between the tire and the liner.
Picture looks a bit high but the angle of the shot makes it look like that.
symalik is offline
Old 06-25-2008, 10:45 AM
  #200
Wezbian
Wezbian's Avatar
Is there an update on the rattle issue? Has BC said anything about a fix, exchange, REFUND?
Wezbian is offline
Old 06-25-2008, 03:53 PM
  #201
Blackjack
Blackjack's Avatar
This whole BC Coilover crap is getting very old... Hopefully this is a lesson learned for those that jumped on the BCs. This is what you get for jumping on the first out... Quality Issues! If I had BCs on my G right now, I'd be pissed and ripping that **** off my car.
I'm done... Will not discuss further.
Blackjack is offline
Old 06-25-2008, 05:32 PM
  #202
symalik
symalik's Avatar
very nice delete my post thats as useless as yours.
symalik is offline
Old 06-25-2008, 06:32 PM
  #203
MaxToTheG37
Super Moderator w/ Boost
MaxToTheG37's Avatar
I didnt delete it... FYI.
MaxToTheG37 is offline
Old 06-25-2008, 07:16 PM
  #204
symalik
symalik's Avatar
blackjack did, i made a comment about his post being useless and off no help to two separate threads, but regardless... back to topic.
Do you still have the same rattle before and after Sharif re tightened everything?
symalik is offline
Old 06-25-2008, 07:40 PM
  #205
MaxToTheG37
yup same damn rattle....
Old 06-25-2008, 07:43 PM
  #206
symalik
symalik's Avatar
Remember how you changed the heights on it? When you first drove home from Sharif's, did you hear the rattle at all? Or did it start after you adjusted it (raised it)?
symalik is offline
Old 06-25-2008, 07:56 PM
  #207
IP37
IP37's Avatar
you guys should try driving around with your rear seat let down.. you should be able to hear the sound better then, and maybe get a better idea of what it could be
i'd buckle the rear seat belts in too if you try it
IP37 is offline
Old 06-25-2008, 07:59 PM
  #208
MaxToTheG37
Rattle was there when Sharif Test Drove it after install... We thought it was the other suspension parts in the trunk or my amp that was loosely mounted in the tire well... but... it never went away....
Old 06-25-2008, 08:01 PM
  #209
symalik
symalik's Avatar
I am going to try that right now on my way home for work, yay to the 1 hour commute and bumpy roads.
EDIT: Nope nothing, same sound with the seat down and seat belts covered in shirts. I am going to try removing the sub box next and see maybe that's the cause.
symalik is offline
Old 07-01-2008, 01:17 AM
  #210
mdracer76
mdracer76's Avatar
How come we didnt get this circled piece with our kits? That might help.
That will also help me raise the car a bit, because the rubber piece on the bottom is so thin, these springs are meant to be put on this, not the stock rubber piece I think.
And they look like they would fit fine if you look in this picture, they are not flat on the bottom, they are shaped just like the rubber piece.
My dining room table strikes again!!
mdracer76 is offline
Quick Reply: Attention All BC Racing Coilover Guys, Check your Rears--Possible Install Error...
