Tanabe NF210 installed with PICS!!!
#47
#50
#51
Interesting.. im also mulling over the tanabe vs eibach dilemma, and I found this thread on the IS forums http://www.clublexus.com/forums/showthread.php?t=237829. Very similar comparo w/ the eibachs (where the tanabes end up with the front appearing a little higher, eibachs appearing more even)..
I think this img was reposted in some other thread.. but in anycase, im leaning more towards the tanabes right now..
#54
I completely agree...not just speed bumps but bad driveways, lower previously harmless curbs, etc....I am going with the Tanabe as well - I like this drop - its also a very stock/OEM wheels/suspension friendly drop...im sure alignment can be put into spec without a camber kit and also tire wear will stay OK......good pics and good call!!!!!!!
#58
lowering a vehicle, or installing most other modifications, does not void any warranties unless they can absolutely prove that the modification caused the issue they are trying to repair.
#59
^ I beleive dealers will tell u,they wont look at the suspension coz u did the springs or shocks. one of the dealers even told me, any little noises they will not look at it because i have aftermarket suspension. they will only look at it if i put my stock springs back on.
