Electronic Adjustable Coilovers
Old 01-08-2008, 02:41 PM
  #31
MaxToTheG37
Super Moderator w/ Boost
MaxToTheG37's Avatar
yea im thinking screw the springs... coilovers will be the best option for the money...
Old 01-08-2008, 03:46 PM
  #32
UNV-IT46
UNV-IT46's Avatar
you can get springs for $180 bucks. Coilover are going to cost you $1000 plus easy plus having the car corner balanced. best for the money? i think not
Old 01-08-2008, 03:48 PM
  #33
MaxToTheG37
Im not going to slack and just get springs... if your going to do it ... do it right... If i got springs I would get performance struts to go with it.
That
vs
Nice coilovers made to work together... adjustable ride and height...
best for money IMO... i think so
EDIT: i just read my reply and someone could take it as being a smart *** ... Didn't mean it to be smart... FYI
Old 01-08-2008, 03:55 PM
  #34
UNV-IT46
UNV-IT46's Avatar
That
vs
I agree with you that coilovers are the way to go. I have had them on every car i own. The only reason i have springs on the G right now is because thats all that is aval, and when coils start coming out i will be buying those too, But my point was coilovers are not the best value. You can get a spring and strut combo for cheaper then you will a set over coilovers.
Old 01-08-2008, 06:18 PM
  #35
MaxToTheG37
I agree 99% with you....
spring strut combo is cheaper
but it depends on the person for how much they value the ability to adjust ride and height... to me its the best value so you can pick your height and not be stuck at a reg. spring hieght...
Thats what i meant... we are both right...
Old 01-08-2008, 06:49 PM
  #36
UNV-IT46
UNV-IT46's Avatar
well for people who cant afford full coilovers and still want to be able to adjust the height they can get ground control system and a strut like koni's. You can then adjust the height and will still pay under a grand for everything
Old 01-08-2008, 07:22 PM
  #37
Kream
Kream's Avatar
UNV-IT46,
When the coilovers are released, I will definately purchase them. Either the Tanabe or Tein EDFC. What sort of alignment service do I need on my car after the install.
Old 01-15-2008, 06:49 PM
  #38
DetroitG37Joe
DetroitG37Joe's Avatar
Yeah I was wondering about whether an alignment is needed after coilover install and if so, just a basic one? Also is camber/toe specs being thrown off an issue at all with coilovers? From what I gather that's only a problem you encounter with springs and OEM struts/shocks - right?
Old 01-15-2008, 06:55 PM
  #39
UNV-IT46
UNV-IT46's Avatar
coilover's alone mean nothing to your alignment. Its how they are set up. What amount of ride height change will you do? dampening settings? The proper install for coilovers is as follows. You should have the set installed by a shop unless you completely know what you are doing. in that case you can install them yourself. After having them installed. You need to go have a 4 corner alignment done. This is not the same as a 4 wheel alignment. You need to find a shop that has experience setting coilovers. The shop will then set the ride height and dampening setting per corner. you should have camber arms installed so the camber can be adjusted. hope this helps.
Old 01-15-2008, 07:50 PM
  #40
RedG37SNC
RedG37SNC's Avatar
Tanabe Sustec Pro FIVE w/ TEAS or equivalent is definately on my list. As far as adjustment, how do they adjust variable height and dampening systems like the Sustec? Do they have to program it and adjust for each of the 16 settings? Any guestimations on what install/corner balancing would cost with 16 different settings? Also since the camber kit isn't part of the system, how would that help, do you just have to pick the best setting that would work with the range your programming.
Old 01-15-2008, 08:23 PM
  #41
UNV-IT46
UNV-IT46's Avatar
The electronic system has nothing to do with height. If you want to adjust the height you will need to get your car in the air take off the wheels and adjust it yourself. The electronic system only does dampening...
Old 01-15-2008, 09:40 PM
  #42
RedG37SNC
RedG37SNC's Avatar
Awe.. to bad, that would be killer, I guess I'll have to keep saving for that Mclaren F1 to get that stuff. Still a drop with comfort or sport a button away... must have.
Old 01-15-2008, 09:46 PM
  #43
UNV-IT46
UNV-IT46's Avatar
Apparently these do, by 1.5 inches... from the site.
Model Year.......................Spring Rates............F/R Height Adj.
Infiniti G35 Coupe (V35) 03- 10.0 / 8.0 -1/4~-1 1/2 in / +1/4~-1 1/2 in TSE5063 $1,590.00
Sustec Pro FIVE delivers broad performance for the track to the streets. Featuring 12-way(16-way with TEAS) front & rear adjustment, FIVE allows drivers to fine tune height, dampening and rebound based on street conditions and driver preference.
The ability to actively adjust height based on speed is freaking awesome, must have.
Sorry my friend you are reading it wrong. The coilovers themselves are not electronic. The only part that is electronic is the teas system. Yes the height can be adjusted 1.5 inches. But not automatically. You must do it manually. Trust me an electronic coilover would cost so much money no one would buy it. The only height adjustable systems are magnectic systems and air systems.
Old 01-15-2008, 10:03 PM
  #44
RedG37SNC
RedG37SNC's Avatar
Yea figured it out and edited..lol. Any idea what the corner balance and install would cost.. ball park.
Old 01-15-2008, 10:36 PM
  #45
UNV-IT46
UNV-IT46's Avatar
Honestly it all depends on the shop. I have seen places charge as little as $100 and jackasses charges $1000 giving a long speech on why they are so great. $150 $200 is fair for a quality 4 corner balance...
Quick Reply: Electronic Adjustable Coilovers
