Coupe Paddle shifter install
Old 07-06-2021 | 07:15 PM
woodieg37's Avatar
woodieg37
So im having problems getting the plastic column peace off. I removed the two taps with the two bolts behide it. And the three bolts on the bottom. Tried everything. Not enough room seem like. Watched a video and it comes right off. Are the coupes different from the Sedans? Figured this was going to be easy install
Old 07-06-2021 | 08:31 PM
ILM-NC G37S's Avatar
ILM-NC G37S
You are probably hung up on the shroud lip that tucks up behind the steering wheel trim:
Make sure the steering wheel is as far forward as it can travel. Then, pop off the upper trim piece. Once the upper piece is free (just flip it up out of the way) you can start tugging at the lower piece at the back (pull down and toward the front of the car.
If need be, and if you have a plastic pry tool, you can wedge it between the steering wheel trim and the shroud and start pulling. You just need enough leverage to clear that lip.
In all honesty, making sure all the screws are out, a good solid pull or two and it should pop out.
Old 07-06-2021 | 09:14 PM
woodieg37's Avatar
woodieg37
Yah I didn’t want to break anything. Is there a part number for the correct paddle shifter column plastic cover or are they all Universal for the paddles ?
Old 07-06-2021 | 09:19 PM
woodieg37's Avatar
woodieg37
I got the paddle shifters off my buddys 370z should work.
Old 07-07-2021 | 10:22 AM
ILM-NC G37S
The paddles themselves should work just fine, same wiring/ connectors. The plastic shroud will likely be different. The shroud should be "universal" across the G37 line, but I can't speak as to compatibility with the Zed.
Old 07-08-2021 | 07:46 PM
woodieg37's Avatar
woodieg37
Okay i got it off. Turn steering wheel 180 degrees and ripped it off, didn’t want to budge, not going back on now. Got lucky and had the pre wires for the paddles. Installed them, nice touch. Just need the bottom plastic trim. Looking for used for no luck on ebay. Found alot of them for Non- paddles.
Old 07-08-2021 | 09:11 PM
ILM-NC G37S
Keep scouring eBay.or any of those other selling sites. They do pop up from time to time and sell lightning fast. When I upgraded to the newer paddles I sold my old set/ cover and they were gone in less than 2 days.
Glad you're getting this project completed!
Old 07-08-2021 | 11:07 PM
woodieg37's Avatar
woodieg37
newer paddles?
Old 07-08-2021 | 11:22 PM
ILM-NC G37S
I swapped to a Q60 Red Sport steering wheel that has the paddles built into the wheel, not on the column.
Old 07-08-2021 | 11:32 PM
woodieg37's Avatar
woodieg37
I like that set up how did it all work out Any modifications to get everything to work
Old 07-08-2021 | 11:50 PM
ILM-NC G37S
(see here)
Those pics are of my first Q60 wheel. I now have a Red Sport wheel that is getting a new leather wrap.
It is not a plug-and-play swap. Not difficult, but not a piece of cake, either.
greco65
01-05-2021 05:58 PM
Broski28
06-15-2016 10:04 AM
shining path
SouthEast
03-08-2013 04:40 PM
VinnysInfiniti
08-20-2011 06:58 AM
a1213f
08-11-2011 01:33 PM
Quick Reply: Coupe Paddle shifter install
