Help Headlight not working on passenger side
Hey guys, new here but hopefully I’ll get some insight. Having some problems with one of the headlights on my 2011 g37x. A couple weeks ago, my headlight stopped working and I got a new bulb for it. Wasn’t working so I returned it and got another one. Still nothing. I checked the fuses in the battery compartment and they look fine which leads me to thinking it might be the ballast. Would I have to completely remove the headlight to take the ballast out? Also I’ve been noticing quite a bit of condensation from the inside of the headlight on that side. Thanks!
Did you have any luck with this?
I'm in the same situation - bought a new bulb but lights not working. I will check fuses and new bulb (and old one) in the working head light to see if the ballast is toast.
If the ballast is toast - where do I get a new OEM - main dealers don't sell them. I can only buy one as part of a whole new head light!!!!
Thanks
Thanks
Thanks
Thanks
IIRC, these units are not sealed, so if you have condensation like OP, it’s ‘normal’. I’d still be pissed...
