Steering wheel rubs against trim
Old 05-19-2019 | 11:38 PM
kinet3k's Avatar
kinet3k
Hi guys,
So I completed a dash replacement DIY due to cracks (Took me roughly 11 hours, i think now I can do it in 5). I think that was the worst DIY i ever had. I had to take sedating pill before going to sleep as I was 100% sure I will never be able to put that back together and now I no longer have a car
But anyways, I eventually managed to put everything together (90% of car being made out of 10mm bolts helps) but what I figured now is when I turn the steering wheel it rubs against the trim. I reassembled the trim 3 times already (i have auto-tilt+paddle shifters) and it's as smooth as it can be and i see no space for improvement there. however, it still rubs. I can loosen the nut and it no longer rubs but wheel feels wobbly then.
i'm 100% sure I didn't have this issue before removing the steering wheel. so I wonder what gives? any suggestions? i know i removed the cluster but the trim is not connected there as well as steering rack/column. is there a way to adjust the distance between steering wheel and column? if there is no scientific way maybe I can add an extra ring somewhere? I need 1-2mm tops.
any suggestions welcome.
thanks!
Old 05-22-2019 | 10:27 PM
kinet3k's Avatar
kinet3k
anyone have any options?
Old 05-23-2019 | 03:30 PM
kinet3k's Avatar
kinet3k
fixed it with M16 washer on the steering wheel hub.
muadib69
25
01-10-2017 12:00 PM
Ryne
12
12-21-2016 12:25 PM
bat6wc
06-13-2012 01:57 PM
Scarz
09-18-2011 11:02 PM
Quick Reply: Steering wheel rubs against trim
