steering wheel hub came unraveled
oh oh, I was taking the wheel off and the entire spool of tape inside came undone. Am I effed? LOL What do I do???
Please Help , Thanks
are you referring to the clock spring it may also be called the cable reel? if so then yes, you should not have torn the damn thing apart, you can try to coil it back into the housing but you are taking a chance of multiple malfunctions including but not limited to srs, horn, steering angle sensor faults. good luck
Build your own bandwagon.
Sorry man—clock spring. Will run you a few hundred bucks. Speaking from experience it's not the easiest repair. Don't bother trying to repair your existing one!
Junkyards are your friend! There are 2 g37 at the local one to my house. One I raped already and tore the clock spring moving to fast. the other is good I’ll try to grab it
Take this as a learning experience. If you've never done something do proper research before starting. I've been working on cars for 20+ years now and I still do research any time I mess with something new, even if I am sure of myself, just to make sure I don't get myself into a mess, like you've gotten yourself into.
Lt8Che
14
06-20-2017 10:24 PM
muadib69
25
01-10-2017 11:00 AM
Ryne
12
12-21-2016 11:25 AM
kchu221
03-01-2012 06:56 PM
Scarz
09-18-2011 10:02 PM
