Passanger side door lock stopped working?
Hi,
Wondering if anyone experienced this or know a fit
My passenger side door handle lock button stop responding, that is, when I
walk close to the passenger side door with remote right next to the handle, press the button on the lock the doors will no response (or it is like the button on the handle failed at all)
It works perfect on the driver side door or if I were to press on the key fob it works as well (unlock once unlock the driver side, press twice unlock the passenger side)
Since it works on driver side but not passenger side, I wonder if resetting the winder/door would help or its other issue
thanks
thanks
If the lock on the passenger side works when you use the fob double click, or press the unlock button inside the car, but not when you use the button outside the car, I would fault the button outside the car. Sounds like your lock actuator is working as it should, since it actuates with other methods.
I am not certain if the button is only available with a complete handle replacement, but that is my hunch.
