On the yellow on the strip is a sequential turn signal with the normal signal as well. then you have the led strip on the bottom as the daytime running lights and then your low beam as the square ones and your high beam as the big round one.
Price wise i will not have yet. we have to finish our test fit do a video and photo shoot then i might have some info on pricing i will update when they hit the market.
As of right now i do not have a price on them. What do you mean by a retrofit kit?
Probably means something you can put inside the original lens covers perhaps? FWIW the Spyder kits are usually pretty well priced so just a simple plug & play would be better than the hassle of trying to unseal and reseal the OEM setup.
I agree that the ideal is to plug and play, and would hope these lenses are well priced especially for early adopters. You cannot get better advertising than us showing them off on the road.
If too pricey, the next best option is to retrofit the existing lenses if that is viable for most of us.
