Backup camera pushed in (pic)
Super Moderator of Pwnage
yep that's pushed in too far. It should fit flush with where the inside of the lip begins.
I cant tell definitively but it looks like a spoiler mounted camera. If so you will likely have to remove the spoiler and repair the bracket that holds the camera. You should be able to get to it from underneath the spoiler
So I had a guy look at it. This was the best he could do:
Doesn't appear to be perfectly "flush" but close enough. I guess it's normal for the infiniti sign on the trunk to be visible on the screen when in reverse.
Anyway, just thought I'd share the update. Thanks for the replies.
im experiencing this too. someone in my college has been pushing it in and now it shows too much of the bumper and even the infiniti emblem. did u find an easy way to fix it?
Still not normal. And what's worse is, it could be leting water in, which could cause you some major headaches. Open it up and figure out why it's not set right. It probably a bent or broken clip.
