Front turn signal question
Is there any trick to replacing the front turn signal bulb - standard bulb?
I was able to pop the burnt out bulb out but the new one will not seat all the way. I am pushing it really hard but it will not stay in. The base looks the same but it will not snap or grab. I don't want to take it to Infiniti
Thanks
Thanks
Thanks
Thanks
Thanks
Thanks
Problem solved.
All the information out there shows bulb 7440NA as the bulb for the 2010 G37. Apparently the 2011 uses 7444NA. My car was built at the end of 2010 production cycle and the 7444NA is the correct bulb.
Strange but true!
Thanks for the help
Strange but true!
Thanks for the help
Need 4 Speed
Wheel & Tires
09-22-2016 07:51 PM
