OEM headlight bulbs wearing out? Good replacement?
#32
I posted this in another headlight thread, but this may be a better place. I have a 2011 G where one of the stock headlights went out. It can be turned on by rotating the dial a few times, but I'm guessing I need to bite the bullet and buy a new pair.
Based on comments here, I'm looking at the following:
Morimoto: https://www.theretrofitsource.com/co...to-xb-hid.html
Diode Dynamics: http://www.diodedynamics.com/store/2...-oem-hid-bulbs
Is either better than the other and the bigger question what color? I want a whiter light than my stock lights. Morimoto comes in 5500k or 6500k and the DD comes in 5000k or 6000k (also have 8000k, but probably too blue). Suggestions?
Thanks in advance.
Thanks in advance.
#36
Anyone have a good argument for a dealership that is denying a warranty claim on my headlight housing bubbling, because I have aftermarket headlight bulbs? I'm honestly shocked that Infiniti is pulling this BS...
#37
Got pics of it bubbling?
Do you have any headlight modifications like swapped STi-R clear lenses?
#38
Originally Posted by Furlow
No headlight modifications. It's like this on both sides. What's frustrating is it was bubbling long before I swapped bulbs, but I didn't complain to the dealership until after I had swapped them.
#41
What aftermarket bulbs are in it right now? I bet they can tell just by looking at the color output. You probably put 5k or 6k bulbs in there.
My 2011 sedan has STi-R clear lenses and painted on the inside black. They are badly bubbling on both sides.
The STi-R clear lenses protrude out further than factory lenses and during the day the sunlight hits the lenses and refracts the light into one concentrated beam that focuses on the exact spot you posted in the picture.
My headlights look horrible up close due to the swapped lenses (protrude out further than oem) and black painted housings.
Honestly i wouldn't worry about it. Yes it is a defect but who else is going to notice it without you pointing it out? Just gotta live with it
#43
For those interested in bulb replacement for the DS2 headlight bulbs, I've purchased the D2S: OSRAM XENARC 66240 CBI from https://www.theretrofitsource.com and to say the least....I am not impressed. The claims of the slight hint of blue is accurate but the intensity on the road is not as bright as the factory bulbs. I noticed my bulbs seemed dimmer than normal and going on 8 years old I figured it was due for a change. After the positive reviews surrounding the brand, I went ahead and tried them out. Stick factory brand or close to factory specs if you after lighting the road well versus the blue color aesthetics these bulbs provide. They are still installed in my car and I do not plan to change them, just my personal opinion. Could be better.
#45
