Coupe trunk will not open
There are a couple of threads regarding this but no diffinitive solution.
Trunk will not open with button in or outside of car and not with key fob, beeps 4 times when using trunk button on outside. Assuming it is a power issue of some sort but hoping someone can shed some more light on this before I go searching for broken wires n the harness. Does anyone know if any fuses are linked to this system?
Thanks
Thanks
Thanks
Thanks
Green wire here too!
I loosen both boots. Pull on each colored wire softly and the green one came up with no resistance. Connect new wire, ran a hangar piece down the rubber tunnel to exit on the bottom with the additional wire hooked on. Connected and all set.
