Dynamic Diode LED Map and Door lights
Installed vanity, map, door, trunk, and license plate bulbs with dynamic diode's led bulbs. I notice while driving that the map and door lights stayed dimly lit. Vanity stayed off. Not sure about the trunk or license. I turned the headlights off and still was faintly on. When I turn the car off, all was off. Should I worry?
It's because of the very low voltage being supplied to your lights at all times is enough to make the LED glow dimly. If you switch your interior lights to 'off' instead of 'door' they will turn off as there's no longer power going to them.
Diode Dynamics (01-11-2016)
The LEDs draw so little (milliamps) that the resting current when the circuit is off can be enough to keep them faintly glowing.
You could install a resistor to prevent it from occurring, but it's not going to cause any issues whatsoever
Feel free to give us a call if you have any other questions: (314) 205-3033
Thank you for ordering with us
Nick C.
Nick C.
Nature of LED bulbs .... a small fraction of line voltage will cause this faint glow. Regular bulbs this voltage is not enough to illuminate them. Live with it or go back to regular bubs.
Feffman
Motorsports / Track
10-17-2016 08:16 AM
itzricky
01-08-2016 09:04 PM
