HELP : KP Technologies foglight module
Old 12-30-2015 | 02:20 AM
Na1ddo's Avatar
Na1ddo
Hello!
I have searched everywhere for a DIY of our cars with pictures, but came out empty. It doesn't help that the forums on kp technologies website is non functional as well.
I am wondering if someone could help with this install. Note: describe it with a how to "dummies" instructions.
Yes, there is a install guide that came with it, but I need it in more layman's term.
2012 sedan
Thanks!
na1ddo
Old 12-30-2015 | 10:13 AM
SonicVQ's Avatar
SonicVQ
I was curious about this module and read the instructions.
Unless you are good with a voltmeter/oscilloscope and routing wire from the instrument panel to the fog light relay, this is not an easy install.
If you don't have experience with this, I would hire someone who has done this before. The risk of a single mistake could be VERY expensive.
Generally is best to stay away from "Universal" anything, as you have to make it fit.
Old 12-30-2015 | 01:34 PM
Na1ddo's Avatar
Na1ddo
Thanks for the advice SonicVQ!
I'm still hoping someone with a successful install, and step by step instructions will come along (unlikely!).
I reside in Houston, TX if anyone is familiar with this module and would like to help install. I will pay you for your endeavors.
Thanks.
Old 12-31-2015 | 02:00 PM
SonicVQ's Avatar
SonicVQ
This may help... It is for a M35/M45 and I would think the G35/G37 would be similar:
KP Technologies Fog Light Controller - Nissan Forum | Nissan Forums
Old 12-31-2015 | 04:38 PM
lobuzz311's Avatar
lobuzz311
Subbed. The module looks awesome, and I'd love to get it, but the install scares me. I've also looked for a good non-electrical-engineer DIY, but came up empty.
Old 01-01-2016 | 03:17 PM
Mr Nurner's Avatar
Mr Nurner
Not trying to change the subject but I was also wanting to get the KP Module but I had a hid headlight harness laying around from a previous car and decided to use that instead of messing with the factory wiring and installed a switch into the blank spot below the trunk/sonar/traction switches, and wired a relay in with it so it turns off/on with the car. I figured that would be much easier. To each their own but for me it paid off. As long as you don't mind a non functional OEM fog switch its an easy solution.
takeapieandrun
21
09-22-2021 02:00 AM
supreme
07-14-2016 11:52 AM
StanfordG37S
01-17-2016 05:38 PM
LousURmind
NorthEast
01-07-2016 10:35 PM
willd828
12-29-2015 11:58 AM
Quick Reply: HELP : KP Technologies foglight module
