dash noises
#31
Pyroclastic Flow
I bought some of this stripping and got it under the cowl without loosening any clips. Just lifted it up slightly with a narrow flathead and pressed the strip in there with my fingers and then the screwdriver when it got stubborn. FWIW, my popping is not solved so I'll probably be taking off the clips soon and doing it the right way. Worth a shot I guess
I was going to use the J strip but couldn't find one at the time and went with a C strip...basically the same thing. Works great and, as mentioned above, looks OEM.
When I secured the cowling back down it very firmly pinned the strip to the windshield. It hasn't move a mm. in the 4 months since. Even with the latest blast of winter here in Maryland.
Sean
#33
I have heard the same from some others. Until they got in there and removed the cowling (not difficult) and cleaned up a bit then put the strip in, it still made a noise.
Sean
Sean
Thanks for the tip. I'll be recovering from surgery for the next couple weeks but after that's done and the weather is a little warmer I'll set a side some time to get the cowl off and clean the whole thing up. I just can't take it for much longer
#34
i didnt use any, but thought of it afterwards. i was thinking more along the lines of some cheap-*** Armor All.
#36
I have a rubbing noise from passenger side's door part whenever my g goes on curvy and bumpy road at low speed (when car chasis twists). I put some silicone lubricant between the windshield and the cowl cover, but the noise was still there. I also applied Teflon tape on the passenger door's glass run where the passenger door's rubber seal touches. But the rubbing noise is still there. Here's my g's rubbing noise from passenger side. (I tried to drive while my boy keeps opening the passenger side door on the bumpy road at low speed, and yes, the rubbing noise was still there even when the passenger side door was opened, and there's no suspension noise from bottom since my mechanic checked).
Here's the rubbing noise recorded sound: rubbing noise
Please help me to fix the rubbing noise. It's been 2 years ...
