Power Window Help needed
Hello. My 09 coupes power window is jacked on the drivers Side. it got stuck going down. I thought it was the motor so I changed that....same thing happened. Bought the $400 switch.....window rolled down....wont roll up. Do you think maybe I got a bad new motor, or is there some weird motor reset I need to do? Please help!
You could keep replacing parts and maybe you'll get lucky.
or
Did you ever checkout the troubleshooting steps in the FSM prior to purchasing and swapping parts?
http://www.nicoclub.com/FSM/G37/Coupe/2009/PWC.pdf
Use a voltmeter for testing
Good luck
Telcoman
si_driver
30
09-03-2019 10:33 AM
