Help Turn signal resistor question
Old 07-25-2015 | 08:06 PM
g37x11's Avatar
g37x11
I was wondering that since the tails as turn module comes with the integrated 6 ohm resistors to prevent hyper flashing, that if I were to add LEDs to the front turn signals, what ohm resistors would I need?
Old 07-25-2015 | 10:47 PM
ttv36's Avatar
ttv36
Race, repair, repeat.
No you need a resistor at each bulb location.
Old 07-26-2015 | 01:18 AM
g37x11's Avatar
g37x11
Yeah I knew that but I know a pair of 3 ohm resistors negates hyper flash for both front and rear led turn signals. But the module has the integrated 6 ohm just for the rear turn signals so I was just wondering if a resistor would be needed if I were to add front LEDs to the turn signal. But I guess the better solution would be desolder the 6ohm and put a 3 ohm in its place. unless someone knows a different solution
e92ry
12-31-2015 08:02 PM
MJ HINX
08-23-2015 10:30 PM
Morgan Thompson
08-19-2015 04:44 PM
kevinmward
08-12-2015 12:09 AM
Quick Reply: Help Turn signal resistor question
