Parcel Shelf Brake Light not working
I was pulled over for my brake light not working on my parcel shelf. I would assume that my tail lights are fine. I have been looking at the field service manual and trying to make heads or tails of it is not easy.
Has anyone had this trouble before? These are LEDs they dont burn out like your traditional bulb does, so I am confused.
Any help would be appreciated.
I can't help you with your specific problem but the notion that LED's don't burn out is false. They do but they just last longer. Check for fuses, use a volt meter to see if they get powered when applying the brakes. All else false, you are close to JBA Infiniti so you can have them take a look at it.
b2autodesigns
Brakes/Suspension
128
03-24-2018 07:44 PM
warpeacelove
10-28-2015 02:59 AM
Skeletor06
08-02-2015 12:54 AM
