Notices
Panamera Shroud Headlights
Old 03-22-2014, 08:23 PM
TwoThree
TwoThree's Avatar
Took me a little while, and the amount of work and customization that went into these was pretty extensive since my headlights are AFS, which for those don't know, is the option where the actual projector moves when the steering wheel is turned. Anyways, here's my setup, for the housing I went with BMW Frozen Metallic Grey which is mostly found on their new body M6. Ran with the Frozen grey for the fog/city light reflector as well. Went with a darker metallic grey called Mica Metallic Graphite for the turn signal reflector as well as the fog light nose cone. Also did an eyebrow in the Mica Graphite, which is subtle and hard to see in pictures, but I think it gave a nice touch. Finally 3M Scotchprint 1080 carbon fiber wrapped side reflector that I installed 3 amber LEDs in. I modded my headlights before and had it fully wrapped and really missed my side marker for some reason, so I made sure I did something about that. Think I fixed it lol. Finally we had the Porsche Panamera shroud. There's been 3 or 4 that 180 has done, all featuring the quad LED, so I wanted to change it up and run a full ring/halo. Ran one of the best halos in the business, the XB LED ring. Very very bright and suppose to be very very reliable. Enough about the specs... Here's some pics... I'll get more up soon when I get some good pictures of them on the car. Oh and also have the TSX-R lens swap. Which man, what a difference, which I had from when I previously did my headlights, but I pulled them apart again and added shims to space out the lens.. The difference is unreal.
blnewt (05-22-2014)
Old 03-22-2014, 08:25 PM
TwoThree
TwoThree's Avatar
Picture of the side marker LEDs
And a shot of the eyebrow
And a shot of the super crisp cutoff line. The line in person is actually a little better, and the color flicker is amazing.
The following 4 users liked this post by TwoThree:
BLamb (03-24-2014), DJMAC (04-02-2014), Presto (03-23-2014), ZOSTER33 (05-22-2014)
Old 03-22-2014, 08:28 PM
Gwhizz
Gwhizz's Avatar
Very nice!
TwoThree (03-22-2014)
TheGanglyGoon
TheGanglyGoon's Avatar
BROOOO!!! SO SICK!! mad props
Old 03-22-2014, 08:30 PM
beers64
beers64's Avatar
Wow very nice man! Looks fantastic and pretty much professionally done. Great job!
Old 03-22-2014, 08:32 PM
monytx
monytx's Avatar
That is sick!! Very nice man!
Old 03-22-2014, 08:58 PM
TwoThree
TwoThree's Avatar
Thanks, I do consider my work professional grade
Old 03-22-2014, 09:10 PM
O2ShootTheJ
O2ShootTheJ's Avatar
now that looks more like the ironman thing to me! nice work
Old 03-23-2014, 01:11 AM
Received 4,943 Likes on 4,176 Posts
Way to make those lights unique and really sharp. Like the side marker LED touch along w/ the whole look of the new shroud/halo combo. BTW, how much did you space your TSX's in mm? I have the STiRs on my Sedan and only spaced them about twice the OEM thickness (just a thicker cardboard cutout), didn't want to use the supplied metal ring spacer as the lens didn't seem real secure w/ that spacer snugged down. If I open them up again I'd like to add a bit more lens spacing to sharpen the cutoff a bit more and increase the blue edge flicker. Your cutoff looks razor sharp!
At any rate, hats off for a top shelf mod
Old 03-23-2014, 02:47 AM
Presto
Presto's Avatar
thank you for being one of the very few who modify the headlights and post a cutoff picture.
that cutoff is amazing, what bulbs are you using? oem?
Old 03-23-2014, 09:16 AM
TwoThree
TwoThree's Avatar
Thanks a lot man, as far as spacer width, I'm not entirely sure. The shims that come for the TSXr lens are not metal, the best way to describe them would be like laminated construction paper. I used 2 of them and the outter diameter is slightly too large to fit in perfectly, so the require very very fine trimming. Not too sure on mm thickness though, I do know it's not much since they're pretty thin.
Thanks man, I'd like for there to be a bit more blue hue on the cutoff itself, there is some, but not a lot. The cut off and focus is incredible though. Ditching the fresnal lens and spacing it out is wayyyy better than OEM. Using OEM Phillips 4300K. Do plan on going with a 6000k fairly soon though.
Old 03-23-2014, 09:22 AM
warped ideas
A quarter past stripped
warped ideas's Avatar
That looks incredible. What talent!
TwoThree (03-23-2014)
Old 03-23-2014, 09:23 AM
The_finest_G
The_finest_G's Avatar
Wow that's amazing!!!
Old 03-23-2014, 03:32 PM
BLAKonBLAKG37
BLAKonBLAKG37's Avatar
Siiick!!! Good work Two Three
Old 03-23-2014, 03:54 PM
dc2r
dc2r's Avatar
have you ever thought of putting another projector instead of the factory one? i heard fx projectors fit in the housing that allows you to keep bi-xenon and afs.
Quick Reply: Panamera Shroud Headlights
