Headlight painted for G37
Try to find some advices regrading to painting G37 headlight. I couldn't find any instructions or sample on how to do this properly without messing up your OEM headlight.
So any thoughts on this guys?
rza2042 (01-22-2014)
Here you go, and while you're at it be sure to change your OEM lens, you can get those at The Retrofit Source Inc the coupe uses the TSX-R and the sedan the STi-R lens.
https://www.myg37.com/forums/d-i-y-i...eadlights.html
Here's another good DIY that you should see~
https://www.myg37.com/forums/d-i-y-i...lens-swap.html
BTW Anthony, I sticky-ed your thread, IMO it's definitely sticky worthy
Here you go, and while you're at it be sure to change your OEM lens, you can get those at The Retrofit Source Inc the coupe uses the TSX-R and the sedan the STi-R lens. https://www.myg37.com/forums/d-i-y-i...eadlights.html Here's another good DIY that you should see~ https://www.myg37.com/forums/d-i-y-i...lens-swap.html BTW Anthony, I sticky-ed your thread, IMO it's definitely sticky worthy
The reason we suggest it is that it's one of those "while you're in there" kind of things. It is a pain in the butt to open up headlights, and it makes sense to mod as many things as possible while you've got them open. But no, it's by no means required.
And yes Anthony, you are now immortal
superjoey
31
03-23-2023 12:56 AM
maybeg37
09-08-2015 03:33 PM
