Notices
Heated seats
Old 12-09-2013, 07:21 AM
ragin_cajuns
ragin_cajuns's Avatar
Heated seats
Is it just me or do the heated seats in the G suck? I turn them on high and can not feel them, not even after driving for 20+ minutes. The heated seats in my previous vehicle (2007 Chevy Silverado) had to be turned down after about 5-10 mins because you could feel it and the heated seats in my wife's 2014 Nissan Pathfinder definitely warm you up as well. Have to take them off of the HI setting after 5 minutes.
Old 12-09-2013, 07:32 AM
KEG97
KEG97's Avatar
Not sure- I definitely feel mine within 5 minutes on the highest setting. The effect is blunted when I'm wearing several layers, but that's to be expected!
Old 12-09-2013, 08:20 AM
wuix2008
wuix2008's Avatar
You should feel the heat within a few minutes.
Old 12-09-2013, 09:11 AM
Vizard_87
Vizard_87's Avatar
I feel it in around 5 mins. then turn it on low and eventually turn it off.
Old 12-09-2013, 09:16 AM
ragin_cajuns
mine must not work then. somehting to have checked out next time at the dealership
Old 12-09-2013, 09:53 AM
Tim30250
Tim30250's Avatar
Between my wife and I, we've had 5 cars with heated seats. The G37 is BY FAR the least hot of them all. I do feel them get warm, but rarely need to take them off the highest setting. All other cars I've owned had to be turned down within 10 minutes or my booty would start to burn.
Fortunately, I live in south TX, so my heated seat season is only a couple months a year. If I was in a colder climate, the lack of heat from the seats would be a bigger complaint of mine.
Old 12-09-2013, 10:13 AM
If you don't feel noticeable warmth within 5 minutes they must not be functioning correctly. They get uncomfortably warm to me when set to high. Even on low the heat is noticeable.
Maybe if your seats have ever been removed the connector underneth the seat wasn't plugged back in correctly?
Old 12-09-2013, 10:29 AM
Jethro
Jethro's Avatar
Yeah, sounds like possible issue with your seat heaters. Mine seem to work great, usually have to turn them down to like 2 or 3 after 5ish minutes even in the cold Chicago winters.
Old 12-09-2013, 10:53 AM
ragin_cajuns
i think they are on. i feel some warmth when i put my hand on them but honestly i wasn't sure if that was from the heated seat or from my body heat after having sat for 20 mins before i checked. i actually left the heated seat on high one day and didn't catch it until 3 days later. that is how unnoticeable the heat is.
Old 12-09-2013, 11:23 AM
guy from norcal
guy from norcal's Avatar
my wife just asked me that last night why they don't get that hot
Old 12-09-2013, 12:16 PM
canucklehead
canucklehead's Avatar
OP - either your seats are not working properly or you have nerve damage in your rear. every G i have ever been in have comparable heat to heated seats in other vehicles. i cannot drive with my seats on High - it's way too hot and quite uncomfortable. in the morning (during winter only) i usually set mine to ~3/5 and then turn down to 1/5 after 5-10 minutes.
Old 12-09-2013, 12:27 PM
skeener
skeener's Avatar
Lowest setting works for me. I usually turn it off after a bit unless I'm expectionally cold to start with. This is in central PA.
Old 12-09-2013, 12:29 PM
ragin_cajuns
lol - no nerve damage here. will have it checked next time at the dealership.
Old 12-09-2013, 09:41 PM
gsm026
gsm026's Avatar
I generally only run mine for 5 or 10 minutes even on low ... after that it becomes uncomfortable through dress pants.
Old 12-09-2013, 09:51 PM
G4FSR
G4FSR's Avatar
Mine works just fine. Warm enough after 5 minutes then have to turn it down.
Have it checked.
Quick Reply: Heated seats
