Weird headlight cut off beam
I noticed that my beam cut off pattern isn't so straight. Then I recently decided to swap to STI-R lenses from TRS. Yes it is clear as day, but I thought it would help the cut off beam to be more sharper but it didn't.
Wondering if anyone else having this same cut off pattern?
Share your cut off beam with me if you have stocks G37 sedans.
I have a 2010 g37s sedan to be exact.
Thanks!
Thanks!
![](http://i43.tinypic.com/21aadfc.jpg)
I have more color (blue) with my sti-r lens swap. I swapped stock spacer with TRS spacer.
Here's someones pics of comparision.
https://www.myg37.com/forums/g37-sed...cbi-sti-r.html
![Frown](https://www.myg37.com/forums/images/smilies/frown.gif)
![thewave](https://www.myg37.com/forums/images/smilies/th_wave.gif)
Are they shipping the STiRs w/ different spacers now? Mine just came w/ one option, the metal rings (about 2-3mm thick). I didn't use them and instead just doubled the thickness of the oem cardboard spacer for a bit sharper cutoff and just a hint of a blue edge. I wish I would've went a bit thicker though.
if you can, can you snap a pic of your beam? from 5 ft away and 25ft away?
thanks!
nguyening (11-14-2013)
G37 sedan projectors with STi-R lenses
I was dealing with the same issue. They guys at hidplanet helped me fix my problem I was having.
![Icon43](https://www.myg37.com/forums/images/smilies/icon43.gif)
![Name: 20130926_210518.jpg
Size: 308.3 KB](https://www.myg37.com/forums/attachments/body-interior-exterior-lighting/149860d1501289455-weird-headlight-cut-off-beam-20130926_210518.jpg)
I wasn't the only one with this issue, but if you read the whole thread a guy in there was playing with spacers and ended up using 2 spacers if I remember correctly. And that hump u see inside the projector will be very noticeable (refer to the first post in that thread to see what I mean)
![NOOO](https://www.myg37.com/forums/images/smilies/no.gif)
Haha yeah luckily I had a 90 degree screw driver. Worked like a charm. Keep us updated on the progress
37
10-17-2020 11:12 AM
Prometheus
General Tech Questions
11-09-2015 01:23 PM
4DRZ
10-14-2015 01:51 PM
