Remove wrinkles on leather seats?
I recently bought a used 2008 g37S. But the leather seats, especially on the driver side, is really beat up with lots of wrinkles and small cracks. Is there any way that I can get rid of them? Or at least make them less noticeable? I hear that leather seats crack when they are dry or get exposed to the sun often, and using a damp cotton cloth and wiping them down will help reduce the wrinkles.
Also, the back seat has a small hole in the leather. Anyone have any advice as to the best way to fix that? I was thinking about just sewing it up.
Thanks a lot. I am really new when it comes to cars and this is my first car that I bought for myself.
Because Racecar
The hole can be stitched up by someone who knows what they're doing. Look around for upholsterers in your area, I would advise against just trying to stitch it up yourself. Leather is a lot less forgiving of bad sewing.
You might try some leather cleaner/conditioner to fix some of the small cracks. The wrinkles are pretty much permanent. There's not much you can do, so I wouldn't worry too much. Cracks are from exposure and not enough care, you can mitigate some of the damage. Avoid using saddle soap. It is an old school remedy that doesn't work and can make your leather worse.
I thought you had a fix LOL even my back seats are wrinkled and I NEVER not once had someone sit in the back . An I use Mcgiuers leather cleaner and condition once a month.
I just think they skimpt on the leather
Dealer service records for my pre-owned 2009 indicate that the previous owner had an issue with driver seat leather that was "bubbled and wrinkled" aproximately one year after purchasing it new. Dealer corrected problem by: "Replaced LF Seat Cushion Cover".
Looks to be a common issue. Just a matter of how insane the price of the dealer's cushion is or if you can find an aftermarket one somewhere.
Just an fyi. You can get some of the wrinkles out with steam. Note, you need to be careful.
Basically, I take a towel and wrap the head of the steamer and spin the excess of the towel up the wand. Hold the towel in one hand (away from you so you don't get burned) and pull the trigger with the other hand. You can sort of iron out the wrinkles. While doing so you are also pulling all the crap off the top of the leather. Follow this up with a LIBERAL application of lexol or similar type leather conditioner. Then after a few minutes buff the residue off.
Here is the machine I have. Found one on cl for $40. Find one, you'll be finding all sorts of things to use it for.
Amazon.com - McCulloch MC-1275 Heavy-Duty Steam Cleaner
