Need some HID Headlight quick help
I was looking into a brighter solution for my HID sysytem. Is it possible to just swap to a different HID bulb for a bit brighter output? I plan to pull my headlights and paint the housings, along with swap in LED switchbacks and LED city lights so I want to have all the bulbs ready when I do this modification.
Any information on a "brighter" D2S bulb?
Infact here are the links for those 2...
Osram 66240 CBIs
D2S: Osram Xenarc 66240 CBI - HID Bulbs from The Retrofit Source Inc
STI-R clear lenses
(3") STi-R - Clear Lenses from The Retrofit Source Inc
these are on my future mod list when I get ready to get my housings painted I'll do the clear lens swap aswell and put in the CBIs, You will love the results !
I already have STI-R lenses sitting in my workshop. Those were widely recommended by many folks here so I didn't want to forget those out. V3 switchbacks from VLEDs and some 5k city lights for my housings as well.
Thanks for the links, I'm definitely going to pikc up a set of those D2S Osram bulbs. I'd like to benefit from a bit more light output as the country roads I drive on frequently don't have any light but what is provided from a headlight.
Any recommendations on fogs?
if you're getting the 5k CBIs along with the STI-R lenses and 5k city lights then you're just like me... Get the 5k 3Five Morimoto HID kit from TRS aswell... when you get the 5k switchbacks installed I want some daytime and nightime pics ! I have switchbacks from VLEDs just not V3s wasn't going to pay $150 for damn LED bulbs while the regular switchbacks I have from them give enough light output IMO..
Also which switchbacks are you using? I'd rather return the V3 switchbacks I have to save some $$$...
I was referring to the question about fog lights... and here is the SKU for the 5k switchbacks - 7443_48_WA2_5K I just checked they don't have them listed on their website now, they do have these but 6k but You should just ask them about the 5k ones.. very likely they are backordered or something... back then when I bought them they were on sale for like 20 or $25 which made me pull the trigger on these over the $150 V3, ...and don't forget the 6OHM load resistors
LED LOAD EQUALIZER RESISTORS TURN SIGNAL BLINKER FIX | 1 PAIR
connoisseurr (11-25-2013)
And thanks for the information regarding the switchbacks and the load resistors. I will contact VLEDS and see what the deal is with the 5k switchbacks. Thanks Mike
The one thing I've yet to find out is what are individuals using for spacers for the STI-R lenses - some say they reuse OEM but it's not enough space, or some use cardboard. I've never swapped a projector lens before so this is something totally new to me.
A quarter past stripped
I went through the same delima when changing my fog lights. After a cut wrist and a few curse words the lights were in.... Till I stood back to admire my work and saw that the drivers side bulb was askew.
I will most definitely be posting many many pictures. I'm currently working on acquiring a good set of quality wide angle LEDs to create some sort of DRL within the projector shroud.
I used the provided metal spacers with my sti-rs; worked great, and lots of color flicker.
#30
Attachment 1
