opinions wanted - paint chrome trim dark
i have a graphite shadow g37s and i want to paint the chrome a darker color and also the wheels. i'm thinking of a dark charcoal or graphite color for the grill, chrome trim around the windows and wheels. oh and back badges too.
i'm not that familiar with powder coating - is that what i would want to do to the wheels or just regular painting?
anyone have pics of a graphite shadow g with all the chrome painted dark?
anyone recommend and good place in the N DFW area to do this?
Because Racecar
BLnewt (Brad) on the forums here has a DIY for covering chrome with vinyl. It's a pretty good semi-permanent way of blacking out the chrome, and there are lots of options as far as color. If you want to paint it, most auto body shops should be able to sand, paint, and clear coat your chrome to give it either that glossy finish or a stealth matte look.
Definitely powdercoat for the wheels - it'll be worth every penny you spend. When you get them powdercoated, you can get some form of high-strength sealant on them so nothing will stick to them (brake dust, road grime, etc). I've done this in the past on a few sets of Ultraleggeras and related one-piece wheels and it's worth every penny.
As for the trim, I'd go with what was stated above about using vinyl. It's cheaper and you can do it yourself with ease.
Yep, just vinyl the trim, I even vinyl wrapped my grill and I'm sure you could wrap the bigger emblems but not the small letters. Here's my trim DIY and they have vinyl in many colors now including a bronze, gunmetal and machined silver among many others.
https://www.myg37.com/forums/d-i-y-i...-g-sedans.html
how long have you had the vinyl installed now? how does it hold up over time?
color fade? edges peel up?
took care of -
wheels - powedr coat
chrome trim around windows - vinyl wrap
grill - probably cheaper to paint than buy the one from infiniti right?
badges? don't want to plastidip them, don't really like the look or texture. options?
Because Racecar
didn't know they were vinyl - thanks for the info.
took care of -
took care of -
Badges- you can always debadge the car, have them painted at the same time as your grille, and reattach them with some industrial adhesive, or you could take a crazy amount of time and smoke them out with VHT niteshade. It's the same stuff that people use to darken their head/tail lights.
like i said when i started the post i want to darkern all chrome trime prefrabley with a charcoal grey color. think charcoal vinyl window trim would look good against the already black pillars or go with black there even though all other trim will be charcoal?
looks like you went with black vinyl - no brainer since your car is black and the pillars are already black.
I think I'd just get a bit more vinyl and do the pillars the same shade, would flow a bit better IMO. There's also quite a few that wrap their grills so that would be an option if you want to keep it the same color, it's a pretty easy wrap job, just get a 3x5 or 4x5' sheet and that should be enough for a couple do-overs if you don't get it right the first time and like I said you should be able to wrap the emblems too (the letters could be done but not having done that I can't say how they'd turn out).
