Notices
Headlights went out
Old 09-25-2013, 09:10 AM
TONY37X
TONY37X's Avatar
Originally Posted by xorbitman
What year is your car and why is the ballast not covered under warranty? You should try changing bulbs. I bought new bulbs 6000K instead of the factory 4300K from www.lumenshid.com The bulbs were $70 a pair! They also sell factory replacement ballasts. Do not get sucked in to paying more than that. Lumens is a very high quality product. Their main factory is located in Ontario, Canada and they use only very high quality parts. For example their HID bulbs use Phillips quartz glass, pure mercury and Sylvania parts and their sockets are from the same factory in Japan that use the special high temperature thermoplastic (PPS) that is used in our OEM bulbs. They also use the Messer Xenon Gas (high purity). It is possible to get a brand new bulb that is defective but that's rare. Also the manufacture OEM replacement ballasts. You can find NEW Infiniti OEM replacement ballasts on EBAY too. ...much less expensive than the stealerships!
Can you buy direct from www.lumenshid.com? I see all their products but no pricing, add to cart or ordering info.
Old 09-27-2013, 08:16 PM
rmfnla
rmfnla's Avatar
Originally Posted by Wreckreation
Aftermarket, I wanted a whiter light so I had to go with a higher Kelvin bulb.
I'd put the OEMs back in and see if they work OK; the problem could just be with the bulbs...
2K1 6T8
10-06-2015 07:40 PM
takeapieandrun
18
09-27-2015 12:36 AM
Allboutcali
09-26-2015 03:43 PM
pauliewalnutzz
09-08-2015 11:41 AM
Quick Reply: Headlights went out
