rear turn signal conversion to LED rings
#32
Yep I figured. But this is still better than the factory turn signal IMO. Did you get my e-mail? My name is Troy (forgot to include who I was on the forums in my e-mail)
#35
Got mine in the mail today.
If this takes you a half hour to install it's either because your trunk was full of junk or you took a 15 minute break between tall lights.
Took me 15 minutes and works FLAWLESSLY.
All you need for install is a pair of crimpers for the connectors.
Bottom line? You NEED this mod!
Thanks Andy !!!!
09 G37x Sport sedan
Jack
Thanks Andy !!!!
09 G37x Sport sedan
Jack
Megacab (06-23-2013)
#40
Got mine in the mail today which I promptly installed. So what can be said about this mod?
1. Requires that you cut some of the turn signal wires but it's relatively simple and you can always wire things back if a guy changes his mind.
2. It's an inexpensive mod that will give your G some uniqueness.
3. As long as you follow the instructions it should only take 30 minutes.
Installed on 2008 X Sedan
#42
