Notices
rear turn signal conversion to LED rings
Old 10-14-2014, 05:38 PM
  #196
ScrewstonNismo
ScrewstonNismo's Avatar
Price shipped to 77377?
Old 10-29-2014, 11:04 AM
  #197
BaapsG37
BaapsG37's Avatar
Email sent! Looking forward to this mod.
Old 12-14-2014, 07:38 PM
  #198
tai01
tai01's Avatar
Email sent earlier this week. Let me know how much the kit is shipped to 91006.
Old 12-14-2014, 09:50 PM
  #199
cmackin
cmackin's Avatar
Email sent.
Old 01-18-2015, 03:02 AM
  #200
tai01
tai01's Avatar
anybody hear back regarding the kit?
Old 01-21-2015, 08:17 PM
  #201
buGfresh
buGfresh's Avatar
I have been responding, just don't post here much. Shoot me an email if interested andy.rushing@gmail.com
Infiniti G37 LED Turn Signal Mod:
Old 02-23-2015, 11:59 AM
  #202
krazyfiend
krazyfiend's Avatar
I see Diode Dynamics came out with something similar..
Diode Dynamics (09-17-2015)
Old 02-24-2015, 01:51 PM
  #203
Diode Dynamics
Diode Dynamics's Avatar
Our Tail-as-Turn™ DIY Kit is $10 here on the site: Tail as Turn Module, DIY - Tail as Turn Modules - Specialties - Lighting
We have a plug and play version coming out soon for the G37 Coupe, and the Sedan will come next. (Waiting on the OEM connectors to arrive!)
The DIY kit installation is quite simple (see video above), but the plug and play version will be available within the next few weeks or so. Retail will be similar to our FR-S / BRZ / WRX / STi kits (~$30) depending on the cost of the OEM Connectors.
Feel free to send us an email if you have any questions: contact@diodedynamics.com
Nick C.
chilibowl (02-24-2015)
Old 02-24-2015, 02:32 PM
  #204
chilibowl
chilibowl's Avatar
Nick C.
You guys are awesome. Just saying.
I will GLADLY spend $10 on this mod!
Diode Dynamics (02-24-2015)
Old 02-24-2015, 02:48 PM
  #205
Diode Dynamics
Send us a PM for the U.S. forum member free shipping code!
Nick C.
Old 02-24-2015, 06:08 PM
  #206
krazyfiend
krazyfiend's Avatar
Nick, which route did Paul go with you personal vehicle to prevent hyperflash? A flasher module or inline resistors? If a module, does DD sell one for the G?
Thanks!
Old 02-24-2015, 07:33 PM
  #207
JSolo
Just say no!!!!!
JSolo's Avatar
I did something similar to this on my motorcycle using a towing tail light converter. I added some additional dual filament teardrop style bulbs on either side of the rear fender. Goal was to have them function as both running, stop, and turn lights.
I believe on this car, all tail light functions are bcm controlled. There is no dedicated flasher module. The module likely contains a resistor for the added load.
@DD a PnP version would be nice. Not a big fan of cutting wires in a newer car. How would the PnP version accommodate the ability to use or not use the stock turn bulb?
From a safety perspective, stock turn signals are poorly visible during the day, esp in midday sunlight. This should help.
Old 02-25-2015, 08:40 AM
  #208
krazyfiend
krazyfiend's Avatar
Looking at the DD website, you seem to be right as they stipulate they don't have a flasher module for the g37. So Paul must have used resistors to fix the hyperflash you see briefly before they cut to the results parts of the video above...Definitely will be nice if the resistor is built into the PnP option w G specific harness bits.
Based off the following video for the FRS/BRZ and another one that was by a third part about doing this install in a newer wrx, I believe if you utilize the the stock turn signal light area along with the led after installing the kit, you need to change the stock halogen to a LED bulb to keep the load within normal parameters.
Old 02-25-2015, 02:10 PM
  #209
JSolo
Just say no!!!!!
JSolo's Avatar
^^Quite possible. The bcm outputs are rated for a particular load. Exceed that and larger issues may ensue. I'd be curious to know what the current rating is of these brighter led bulbs. I briefly glanced at the DD site last night after reading this thread but didn't find this spec listed.
Old 02-25-2015, 04:34 PM
  #210
Diode Dynamics
The G37 has a built-in (non-replaceable) flasher module, so you'll need to install inline resistors to prevent hyperflashing
A 6 ohm 50 watt resistor per turn signal should do the trick (common size). It's really not that bad! I'll see if I can have that included in the install video for the plug-n-play kit
For those of you worrying about the factory LEDs failing prematurely, they won't be driven beyond the factory specifications so you won't increase the odds of them failing. OEM LED setups go through rigorous testing to ensure they outlast the vehicle.
I'm sorry if I've missed some of your questions. We will post more when a PnP version is released. Feel free to give us a call: (314) 205-3033
Thanks!
Nick C.
Quick Reply: rear turn signal conversion to LED rings
