Has anyone removed haze on the INSIDE of their headlights successfully? I think I remember someone said to not do it because the inside doesn't have a protective film like the outside has & if you were to clean it, you might scratch it up and make it more hazy. I just wanted to ask before I tried some things on it. any input would be helpful! Thanks
Yeah, I tried to clean the inside and it was damaged beyond repair. Try and avoid using products on the inside. You can wipe it with a microfiber cloth lightly.
I have condensation in both of my lights and I was told I could clean the inside of mine but very lightly because it's not recommended. But in my case it's the only way to get the condensation out.
May I ask You why You have haze inside headlight? How old they are? Tx.
How would just swishing it around work? Have you heard someone having success with that??
I don't know. It was just a thought. It could only be a thin film of something that needs to be rinsed out. Do you think it needs like a cut and polish or something?
