Wiring Daytime Running Lights
I have a 2010 G37X sport sedan. I just had the daytime running lights installed. I noticed that the lights turn on when the engine is on. The DRL turn off when the parking lights or headlights are on. My question is how do you rewire the DRL so that they can be on with the headlights on.
Thanks
Gabe
Thanks
Gabe
Get a switch like this instead.
http://www.ebay.com/itm/290610169669?redirect=mobile
Hook up the optional headlight wire to your fogs, and that should do the trick. They should work just like the video. They'll turn off only when the fogs are on, but not when the headlights are on. Good luck.
I replied to your PM, but I reread your question...
I made a direct connection at the battery terminal, so the LEDs come on immediately when the engine is on and stay on with or without the headlights on. There's about a 5 second delay for the LEDs turning off after the engine stops.
I opted not to tie the LEDs to the fogs, so they also stay on when fogs are switched on. With just three LEDs down low on each side of the fogs, they are somewhat subtle and not overly done, so I like them on all the time.
When you hooked them directly to the battery, what did you use to convert it to just a 12v charge to not overload the LEDs? I just bought a pack of LED daytime running lights, and they only come with wires to connect it to...well, something else, but the manufacturer doesn't really specify what to connect them too actually.
If this is the same set you have, there should be no problem wiring direct to the battery.
superjoey
31
03-22-2023 11:56 PM
Lt8Che
91
04-08-2022 04:55 PM
