Notices
'09 Sport Sedan Fog Lights Question...
Old 03-11-2013, 09:39 PM
oliveview
oliveview's Avatar
DJ Hellfire:
You're running HID, not HIR, in the fog light spot? What about the extra pieces required to run HID?
Old 03-11-2013, 11:46 PM
Yan141
Yan141's Avatar
HID should be pnp.
Old 03-12-2013, 11:27 AM
ChuToy
ChuToy's Avatar
I went with Diode Dynamics HID conversion kits for my fogs and they are 9006 bulbs as well. I have a 2009 x non-s, but the fogs are in the headlight housing. Install was easy and it was just the fact of putting the small ballast somewhere. I also swapped the stock HID headlights to 6000k bulbs to match color.
Before:
After:
Old 03-12-2013, 12:27 PM
infinmyg
infinmyg's Avatar
2009 Infiniti G37 Sedan Light Bulb Size Chart:
Low Beam Headlight Bulb Size: HID-D2S
High Beam Headlight Bulb Size: HID-D2S
Parking Light Bulb Size: 2827
Front Turn Signal Light Bulb Size: 992 (7440A)
Rear Turn Signal Light Bulb Size: 7440
Tail Light Bulb Size: LED
Stop Light Bulb Size: LED
High Mount Stop Light Bulb Size: LED
Fog/Driving Light Bulb Size: 9006
License Plate Light Bulb Size: 168
Back Up Light Bulb Size: 921
Front Side Marker Light Bulb Size: 2827
Rear Side Marker Light Bulb Size: 194
Map Light Bulb Size: DE3175
Trunk/Cargo Area Light Bulb Size: 158
Old 03-12-2013, 12:45 PM
oliveview
oliveview's Avatar
Thanks! My wife took the G to work today, so I don't have access to the manual.
Old 03-12-2013, 12:49 PM
oliveview
oliveview's Avatar
Before:
After:
Okay, thanks. I would have to assume that adding the HID bulbs to the fog banks must add some serious illumination, yes?
Old 03-12-2013, 12:58 PM
ChuToy
ChuToy's Avatar
A large amount actually, but they do aim lower so it doesn't seem to annoy other drivers.
Old 03-12-2013, 01:17 PM
oliveview
oliveview's Avatar
I forget. Do the fogs stay "on" when the brights are activated? Or does that cancel them out, like most factory cars?
Old 03-12-2013, 02:38 PM
ChuToy
ChuToy's Avatar
They do not stay on when you turn on your brights.
Old 03-19-2013, 05:30 PM
jktinen
jktinen's Avatar
What is the clear lense? anyone have a picture?
Originally Posted by Yan141
if you want output, Go with HID 9006 3000k yellow then swap your oem lens with 3" clear lens and enjoy the show at night.
Old 04-18-2013, 09:08 PM
Yan141
Yan141's Avatar
This is what you get when u swap to sti-r clear lens
Old 05-02-2013, 04:05 PM
hhyder
hhyder's Avatar
i wanted to swap the ugly white fog lights on my car with bright yellows and ordered a pair from ebay. i got the 'H1' bulbs. is that the correct size?
H1 DT 3000K Xenon Halogen Yellow Replacement Fog Light Bulbs Replacement | eBay
Old 05-20-2013, 01:46 PM
hhyder
hhyder's Avatar
UPDATE: i got the bulbs and tried them out. took the intake out and got the fog lights from there. came to find out the hard way that h1 is the wrong size reread this thread and now realize that i should have ordered 9006
Old 11-07-2013, 09:10 PM
  #29
svhomicide
svhomicide's Avatar
Originally Posted by DJ Hellfire
I have 3000K HID's in mine. Nice and bright! And they are 9006! They are considered foglights because they aim lower than the low beams!
Is there a stocket to put a bulb for the fogs or do I need to buy a 9006 hid kit and wire it myself
superjoey
31
03-22-2023 11:56 PM
Thedbarz
33
02-09-2016 12:05 AM
sydnrusty
11-21-2015 10:42 PM
bikerjosh
08-19-2015 11:26 PM
Quick Reply: '09 Sport Sedan Fog Lights Question...
